Chain
I was not able to create a chain on Inventer with the single sized link in the kit of parts.
Was anyone able to do this? |
Re: Chain
our team was able to. its a witch with a b to get it done, but its possible. there is an actual chain selection, its just hideing.
Re: Chain
Inventor has a feature called "Chain Generator"
If you search in the help menu of Inventor you can find instructions on using the tool. check out this video if you want a quick overview. http://usa.autodesk.com/adsk/servlet...112&id=9444974 |
Re: Chain
I searched my schools inventor help and didn't find it
Re: Chain
so theres a help in the program to generate chain instead of making each link
Re: Chain
at least, there should be, but ours doesn't have it
#7
Re: Chain
Yea we looked into this but the chain generated only has two gear positions. Two of the chains we are using contact at four points. Another two chains contact at three points. Plus when using those parts we were unable to make the files even visible. They were only visible when selected. If we were to use chain generator using ANSI 40 would this hurt or improve chances for the Autodesk Visualization Award?
#8
Re: Chain
Let me know if you can't find it, I will put up a screenshot |
#9
Re: Chain
is it the roller chain generator or is it called something else and can we use the sprockets for the gears instead of the ones that are generated already in the roller chain generator because it keeps creating a new gear for it
#10
Re: Chain
The roller chain generator default in Inventor has a few quirks.
I suggest using one of thee 3rd party auto chain generator if you are having trouble. http://www.sdotson.com/viewparts.php...20transmission (check out the link with rollerchain.zip) Let me know if you have trouble getting it to work |
#11
Re: Chain
Hey guys... Just wondering, can anyone tell me how they constrained a chain using the .ipt files in the KoP for their drawings? I've never done chain before... only belts. I personally don't like the chain generator in Inventor (I mean, the chain looks like a belt...), and was wondering if anyone knew how to go about using .ipt files and making/constraining the chain. I've created a chain with the correct amount of links and everything... I just don't know where to go from there (I tried constraining it and got frustrated when it wouldn't work after a good hour)
Thanks! -Zach Last edited by pearldrumzach : 28-01-2009 at 16:57. Reason: didn't read closely |
#12
Re: Chain
If you made your own custom model chain ipt file, please post the file so others can understand how to help. |
#13
Re: Chain
In an ipt file create a sketch for the path of the chain (actually I think the DAcc already does this for you).
In the ipt with the path create a workpoint on the path. Use the Rectangular Pattern command (should be called Curve Driven Pattern - where often the "curve" is a straight line) to pattern the workpoint but the center-to-center distance of the chain link (pitch). In the assembly constrain one link to the first two workpoints on the path. In the assembly use Pattern Component and use the "Rectangular Pattern" feature of the Workpoints to pattern the rest of the chain links. http://www.chiefdelphi.com/forums/at...9&d=1200330921 |
#14
Re: Chain
I used the chain .ipt files in the Kit of Parts files downloaded from FIRSTbase.
JD - I created a chain, with the correct number of links. I am just unsure how to go about constraining it within the whole assembly of the robot. Is there any way I can make the chain "work" (I don't know the real word for it, but by "work" I mean can I constrain it in any way to where the chain will turn when the sprocket turns in the assembly)? Thanks for the help, guys. Last edited by pearldrumzach : 30-01-2009 at 13:13. |
#15
Re: Chain
Just wondering if there is a way to replace the beltish look of the chain generator. Honestly it doesn't look like chain at all. Plus our team uses ANSI 35 chain and the generator only has ANSI 40 for the smallest chain. Does anyone know how we could use ANSI 35 in the generator?
| Chain | hong12891 | Inventor | 8 | 05-02-2007 20:03 |
| Chain Drive chain | Damelvin | 3D Animation and Competition | 2 | 15-02-2005 00:19 |
| 25 or 35 chain? | Alan Ing | Technical Discussion | 24 | 02-03-2003 13:56 |
| Chain and chain breaker source? | kmcclary | Off-Season Events | 4 | 22-10-2001 22:51 |
| chain | Lake Orion | OCCRA | 1 | 30-09-2001 13:20 |
