Go to Post If you want to change the culture sometimes you need to change a little yourself - Koko Ed [more]
Unread 17-01-2009, 18:52
FearlessLeader FearlessLeader is offline
AKA: James Wittel
FRC #2753 (Team Overdrive)
FearlessLeader is an unknown quantity at this point
Reading Joystick Values Help
I need to get the value off the X axis on Joystick(1) the value being 0-256
I need to put the value into a float(JoyStick1Value)
How do I do this code please if you can
Thanks
Team Overdrive #2753 - FRC 2008/2009
FTC 2007/2008 world champions!
New Brunswick Eruption - Future Glory Award
Attending NJ Regional
Attending NYC Regional
www.teen-technology.org
www.JPEX-studios.com
www.team-overdrive.com
Past: FTC #74, FVC #3179
Unread 17-01-2009, 19:12
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: Reading Joystick Values Help
Look in BaeUtilities.h the NormalizeToRange() function
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 17-01-2009, 21:33
AKA: James Wittel
#include "WPILib.h"
#include <Joystick.h>
class RobotDemo : public SimpleRobot
RobotDrive MyRobot;
Joystick RightStick;
Joystick LeftStick;
public:
RobotDemo(void):
MyRobot(1, 2),
RightStick(1),
LeftStick(2)
GetWatchdog().SetExpiration(100);
void Autonomous(void)
void OperatorControl(void)
GetWatchdog().SetEnabled(true);
while (IsOperatorControl())
RightStick.GetX(); //this is what i need help with
START_ROBOT_CLASS(RobotDemo);
I know i use this but RightStick.GetX(); where do i put the float to get the value
Unread 17-01-2009, 23:08
wt200999's Avatar
Texas Instruments
AKA: Will Toth
What are you trying to do with it?
Unread 17-01-2009, 23:13
Alexa Stott's Avatar
Alexa Stott Alexa Stott is offline
All I do is twin.
AKA: elixir
FRC #0025 (Raider Robotix)
Alexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond repute
Send a message via AIM to Alexa Stott
Are you talking about doing smething like:
float variablename = stick.GetX();?
I don't really undestand what you are specifically trying to do.
|Email:alexastott[at]gmail.com|Facebook|@zelixir|Google+|
[University of Maryland Computer Science, Psychology]
[Brunswick Eruption]
Unread 17-01-2009, 23:33
AKA: James Wittel
I am sorry i figured it out
(float) = RightStick.GetX();
Joystick values (?) beefy1 Programming 1 23-12-2008 11:26
Joystick axis values in new controller koreabell Programming 7 17-12-2008 11:39
Joystick Output Values? compwiz2008 Programming 5 17-01-2008 22:40
Mixing Joystick Values for mecanum wheels Leav Programming 10 15-01-2006 14:51
Need Help reading PDF files Tton General Forum 6 14-02-2003 17:43
