Accelerometer Help?
I'm trying to use the accelerometer example to see if I can set a specific acceleration rate but everytime I run it over the cRIO it doesn't work. And I don't get the values it shows not even with the manual and 10 people reading it
![]() Some help? |
Re: Help?
When you say "it doesn't work," what do you expect it to do and what does it do instead? How do you have the accelerometer connected? Please give as much detail as possible so that we can all work together to narrow down the problem quickly.
Re: Help?
I have the cRIO connected via wireless.
I was expecting that when I ran the .vi I could accelerate and it would show me the rate of acceleration but when I move my joysticks it doesn't do anything at all ![]() I left the default settings cause I don't understand what they mean ![]() |
Re: Help?
I'd check your wiring first. What ports are the accelerometer plugged into? Is that analog bumper working? Please fully explain your wiring.
What happens when you shake the accelerometer? The settings indicate the middle point and the sensitivity of the sensor. Basically, they help map voltages to accelerations. EDIT: Moderators - Can one of you please rename this thread? |
Re: Help?
A quick build on the last post. Are you using the dashboard? If not, do. This will help you ensure that your accelerometers are indeed working and plugged into the ports you think they are. (The dashboard helped us!)
Re: Help?
Does the cRIO have an accelerometer...?
#7
Re: Help?
No. The accelerometer is a separate board.
#8
Re: Help?
So that means we need to buy one right?
#9
Re: Help?
No, one came in the kit of parts. It is a red board that is 1" square that says Accel on it.
It is shown on page 2 of http://usfirst.org/uploadedFiles/200...r%20Manual.pdf |
#10
Re: Help?
Is it the piece connected on top of the cRIO. Connected to one of the slots?
The Digital one? |
#11
Re: Help?
No. The Accelerometer came in the padded manila envelope in the KOP and doesn't attach to the cRIO modules.
It needs to be physically wired before it can be attached to anything. It's just a bare 1" square circuit board. |
#12
Re: Help?
Then we are missing it
Cause I just went out to look for it and I didn't find it...I'll keep searching.... After that I guess I'll figure my way out... Also, I want to set a specific speed to the jaguars but I can't find where to do it. I used all the motor examples available but none of them save the settings when I use the joystick...Any help? |
| accelerometer help!! | wildcats | Electrical | 2 | 18-01-2009 15:51 |
| Help with accelerometer. | ThisIsFood | NI LabVIEW | 6 | 17-01-2009 12:40 |
| Accelerometer Help! | Questions4mQ202 | Electrical | 4 | 15-01-2009 19:44 |
| Accelerometer help | Red Mage | Programming | 3 | 30-01-2008 18:49 |
| Accelerometer Connection Help | crazykid234 | Electrical | 2 | 11-02-2005 08:23 |
