Go to Post in other words, "always have something to do that will change up your life" - Nawaid Ladak [more]
Unread 19-01-2009, 15:34
3DWolf's Avatar
3DWolf 3DWolf is offline
Boots - Head Programmer / 3D
AKA: Jake
FRC #1502 (Technical Difficulties)
3DWolf is on a distinguished road
Send a message via AIM to 3DWolf Send a message via MSN to 3DWolf
Code Base
Where am I supposed to start entering everything in for actual coding? The guide mentions classes like the SimpleRobot and IterativeRobot classes, but where are you supposed to put those? Are they build into the WPI libraries already? Scrolling through the library I didn't sort of main function or any base file to start entering code into.
Am I thinking about this the wrong way or do I have to enter in another class file and what not?
My reasoning behind this thinking is the code in previous years had the files like user_routines.c where you put all of your teleop code. The guide showed the SimpleRobot class had the init, Autonomous, and the teleop all compiled into one, but I'm just at a loss on where to put/get that file.
(Sorry for being so run around, I'm bad at wording what I actually mean)
You can call it the programming teams fault, but we'll just force your arguments nil.
There are 10 kinds of people in the world -> Those who understand binary and those who don't.
WYSIWYG - In FIRST: Greatness
Unread 19-01-2009, 15:51
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: Code Base
Do you have windriver installed?
Go to file -> new -> example
then pick VxWorks Downloadable Kernel Module Example Project
then choose an example that starts with FRC (try the simple robot demo)
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 19-01-2009, 16:01
3DWolf's Avatar
AKA: Jake
Re: Code Base
Bah OK there it is, thanks.
Unread 19-01-2009, 16:48
3DWolf's Avatar
AKA: Jake
Re: Code Base
OK to avoid creating another thread, and its similar in nature anyway:
How the fork do I set up the connections to download code to the robot?
The guide is VERY VERY vague in this, as it just says
1. Download
2. Reboot
[facepalm]
Do I have to set up cables through the drivers sation then to the cRIO? Or can I just go straight from the laptop to the cRIO? And I assume the IP on the laptop has to be the 10.xx.yy.6 IP in order to download?
2009 base C/C++ code? Maxpower57 Programming 15 24-10-2008 21:02
Circle base vs. Rectangle base Pelicano234 Technical Discussion 13 15-01-2008 16:49
Looking for Base Code Eric W. Jones Programming 2 30-10-2006 18:54
Knowledge Base Leon Machado IV Programming 15 02-08-2005 12:24
