Go to Post There's a fine line between idolizing someone and stalking! - Jay H 237 [more]
Unread 19-01-2009, 17:48
emhw1994 emhw1994 is offline
FRC #2458
emhw1994 is an unknown quantity at this point
Mobile Device Controller
Since we haven't gotten ours.......We just wanted to know if anyone has gotten their mobile device controller power adaptor in your kit of parts. Thanks!
Unread 19-01-2009, 17:52
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Re: Mobile Device Controller
? The kit doesn't include a power supply for the cRIO (aka Mobile Device Controller). You're expected to connect it to the PD per the Power Distribution Diagram.
Russ
Unread 19-01-2009, 22:49
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Already attached to the cRIO is one half of the connectors you will need to make your cable. On the end the little black connector with 4 holes. In your KOP there should be another one, using these two connectors use a piece of 2 conductor wire 20 AWG or larger (meaning larger diameter).
-Mike AA
pic: iPhone and Mobile Device Scouting Web Application kiettyyyy Extra Discussion 8 06-05-2008 10:39
Unknown device id (0) paulcd2000 Programming 7 12-02-2008 19:48
Signaling device?? Bruceb Rules/Strategy 1 29-01-2008 10:40
Unknown Device ID(0) DavidGitz Control System 13 28-01-2008 20:28
Like Device sasquatch General Forum 6 31-01-2002 08:51
