Go to Post This is just one example of why you MUST NOT make engineering decisions based on assumptions. You should check/measure your parts and make appropriate design adjustments. - Stu Bloom [more]
Unread 19-01-2009, 20:50
KTjen2967 KTjen2967 is offline
FRC #2967
KTjen2967 is an unknown quantity at this point
Ball Bearings on PVC
Will a standard 608 bearing -- approximately 7/8 of an inch -- fit into any type PVC pipe? In other words, has anyone used PVC with skate bearings at all?
Unread 19-01-2009, 21:01
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: Ball Bearings on PVC
While I'm not sure about PVC (since PVC pipe has weird sizes for it's ID and OD's), you can go to McMaster and buy polycarbonate round pipe in fractional sizes that will fit around a .875" bearing. If polycarbonate pipe is too expensive, you can also buy PETG pipe, which is similar to polycarbonate buy about half the price.
Art Dutra IV
世上无难事,只怕有心人.
Unread 19-01-2009, 21:07
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
608 bearings are 22mm (about 0.866 inch) outside diameter. They are among the worlds most commonly used bearings, as skateboarders everywhere will attest.
3/4 inch schedule 40 PVC pipe is about 0.804 inch inside diameter with about 0.113 inch wall thickness. So if you can bore the pipe ends out to suit the 608 bearing, you'll have about 0.08 inch wall thickness remaining. Should be strong enough assuming you aren't loading the pipe heavily or supporting a very long span.
[edit]A convenient feature of 608 bearings is their 8mm inside diameter. This makes them useful with metric M8 or unified 5/16 inch bolts as spindles. When used in small electric motors, 608 bearings can support either 8mm or 5/16 inch shaft extensions easily, because there is only 0.002 inch difference between those sizes.[/edit]
Richard Wallace
since 2003
Unread 19-01-2009, 22:36
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
also 1" OD 1/16" wall round aluminum tubing is pretty common at hardware stores, has 7/8" ID, and you can find FR6 bearings, with a 3/8" hole and 7/8" OD, on the internet and at our favorite robot parts suppliers such as AndyMark and Innovatin First Inc.
Ball Bearings Mrtrom General Forum 3 30-01-2008 18:26
Purchasing Ball Bearings FIRST JerseyKid Kit & Additional Hardware 7 30-04-2007 09:11
Where to buy Ball Bearings? ThatIndianKid89 Kit & Additional Hardware 3 20-01-2007 15:59
Threaded rod through ball bearings Madison Technical Discussion 38 03-01-2007 01:23
Drills: The ball bearings are gone? BobbyG Motors 0 21-01-2003 23:57
