Go to Post Does IR work underwater? Or more importantly, through an air-water interface? ... sigh ... - Rich Kressly [more]
Unread 19-01-2009, 22:39
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
running program on startup
We successfully ran the original code on our robot and controlled it over the configured wireless connection. We made modifications to the code and uploaded it to the cRIO. However, our revised code only runs when we have the bot tethered to the driver station and the code running in labview on the laptop connected to the driver station. We have tried power cycling the bot and controlling the bot over the wireless connection but it is unresponsive.
Does anyone know how to run the bot over the wireless connection with the code running upon bootup?
Unread 20-01-2009, 09:31
Re: running program on startup
You need to download a stand-alone application and set it to run at startup.
The process is described starting at the bottom of page 5-5 (pdf page 59) of the FRC_Programming_Guide.pdf installed with the latest LabVIEW Update at:
C:\Program Files\National Instruments\LabVIEW 8.5\manuals
Unread 22-01-2009, 14:21
FRC #2477
Thanks a lot Mark!
cRIO Not Running Program railerobotics NI LabVIEW 5 18-01-2009 08:48
Attach console at program startup virtuald C/C++ 2 11-01-2009 11:05
Compressor Startup Spiders Pneumatics 7 11-02-2008 15:15
Running program without transmitter bear24rw VEX 3 15-11-2007 23:41
How to keep a program running at a school which doesn't get it? Jimmy General Forum 9 03-04-2003 10:08
