Go to Post a robot is never finished... It can always be redone and improved. - EricVicenti [more]
Unread 20-01-2009, 00:41
morganh2550's Avatar
morganh2550 morganh2550 is offline
Actuationator
FRC #2087 (BFG)
Team Role: Electrical
morganh2550 is just really nicemorganh2550 is just really nicemorganh2550 is just really nicemorganh2550 is just really nicemorganh2550 is just really nice
Exclamation fried cRio???
we to hook up a resistor to try to measure to current to the motor and when we turned on the robot, it worked for a while then just died and the cRio will not turn on. any ideas!!???
Unread 20-01-2009, 07:40
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Re: fried cRio???
How were trying to measure motor current? If you were simply placing a resistor in series with the motor leads and then doing a differential voltage input to the Analog Breakout, I can't think of any way that a failure within that circuit would break the cRIO or its 9201 analog input module. I could believe that you've fried the Analog Breakout adapter module but you shouldn't be able to take down the cRIO with a resistor.
What size resistor did you use? Keep in mind that motor currents can exceed 100A for short periods. Let's just imagine that you used a 50 milliOhm current sense resistor - there would be 5V across that resistor (100 * 0.05) and 500W being dissipated for a short period of time. In other words, all resistances in the path from the battery to the motor need to be in the single digit milliOhm range to keep from frying.
More details please...
Russ
Unread 20-01-2009, 23:45
Actuationator
FRC #2087 (BFG)
Re: fried cRio???
we used a 0.1 ohm resister?
Unread 20-01-2009, 23:57
Re: fried cRio???
Have you been following the setup procedure outlined in http://www.usfirst.org/community/frc....aspx?id=10934?
I'm curious to know whether you had been successfully using the system before attempting the current measurement.
Do you have a set of schematics that you've been using or can you post a picture?
Russ
Unread 21-01-2009, 00:04
Re: fried cRio???
Please measure the voltage that is being given to the cRIO.
Unread 23-01-2009, 00:19
Actuationator
FRC #2087 (BFG)
Re: fried cRio???
we believe the reason for this that we wired the to the resistor backwards we do not know why the bumper did not fry before the cRio.
Unread 23-01-2009, 00:33
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: fried cRio???
Resistors do not have a polarity, it is not possible to wire a resistor backwards.
Unread 23-01-2009, 14:55
BLAQmx's Avatar
BLAQmx BLAQmx is offline
Software Engineer
no team (National Instruments)
BLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of light
Re: fried cRio???
cRIO and its modules are electrically isolated to prevent this from happening. If the cRIO is damaged it is very unlikely it was caused by running to much current into the AI module.
Have you called NI for support? If you cRIO is damaged we will overnight a new one to your team.
NI FIRST Community: Where to go for LabVIEW, Wind River, cRIO-FRC, and NXT support.
Unread 23-01-2009, 20:47
crake crake is offline
AKA: Chris Rake
no team (Athena)
crake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond repute
Re: fried cRio???
This unit has already been RMA'ed, but we haven't gotten the unit from the field. NI has 100% debug on all returned FRC controllers so we'll snag it once it arrives to take a look and determine root cause.
Unread 24-01-2009, 01:26
Actuationator
FRC #2087 (BFG)
Re: fried cRio???
we got a new cRio but we are still confused as to why it died in the first place
Unread 24-01-2009, 09:44
AKA: Chris Rake
no team (Athena)
Re: fried cRio???
We'll take a close look once we receive it.
Unread 24-01-2009, 15:59
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
Re: fried cRio???
when any electronics fry, they produce blue smoke (or so i've been told)
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Jaguar Fried? Sovietmagician FRC Control System 0 19-01-2009 23:27
IR might be fried team877 Sensors 5 04-03-2008 09:27
IR Board Fried? JCODER Sensors 23 15-02-2008 16:37
We fried an 884 Andrew Electrical 13 17-08-2003 23:02
fried archiver 2000 4 23-06-2002 22:45
