Go to Post we came together, worked our butts off, and eventually looked at failure and decided....its just not our style. - Monochron [more]
Unread 21-01-2009, 13:34
mahmosh's Avatar
mahmosh mahmosh is offline
FRC #1946
mahmosh is an unknown quantity at this point
error when build the project for the camera tracking
when i tried to build the project TwoColorTrackDemo-v2 that i got from the frc updates ... i got that error
C:\Users\D777~1\AppData\Local\Temp\make33005.sh: ccppc: command not found
C:\WindRiver\workbench-3.0\x86-win32\bin\make.exe: *** [TwoColorTrackDemo/Debug/Objects/TwoColorTrackDemo/Target.o] Error 127
Build Failed in Project 'TwoColorTrackDemo' (Process Exit Value was 2):   2009-01-21 19:50:57   (Elapsed Time: 00:01)
please help me step by step how to solve this problem?
Unread 04-02-2009, 14:47
pheadxdll pheadxdll is offline
AKA: Alex
FRC #1225 (Amperage Robotics)
pheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud of
Re: error when build the project for the camera tracking
I got the same error ccpppc make not found.
I deleted every project in windriver.
I went into C:\windriver\workspace and make sure every folder was deleted. (except for .metadata)
I restarted windriver.
I loaded a new TwoColorTrackDemo example.
Boom, it builds without errors. Probably something intermediate.. >.>
Amperage Robotics Team 1225
Site under-going revamp. :/
How to make the camera search the light instead of only follow when targeted? jesusescobar Programming 4 18-02-2007 16:56
Desperate for help in camera tracking itsme Programming 9 06-02-2007 15:55
Where is the multi object tracking code for the RC? EHaskins Programming 52 17-01-2007 11:55
camera jerks and does not lock on when tracking kirkio Programming 2 10-02-2006 23:43
Error in Compiling the Camera Code (B&W Version) VetteSlick Programming 7 20-01-2006 20:50
