Go to Post Our wheels just keep falling off. - SenorZ [more]
Unread 22-01-2009, 14:34
Sykan's Avatar
Sykan Sykan is offline
Lead Programmer
AKA: David
FRC #0540 (Team 540)
Sykan is on a distinguished road
Vision Assistant help?
Hello,
Is there a specific command in Vision assistant to get the camera to tell you the area or bounding box of the color. When i used color location it shows up as a little box in the color instead of the whole color. Or am i going about this all wrong?
Thanks,
David Elizondo
(Programmer)
Unread 22-01-2009, 16:17
Re: Vision Assistant help?
Once you have a binary image, the output from a threshold, you can use the particle analysis step. It has lots of measurements by default, and a button to select which measurements you want.
Greg McKaskle
Unread 22-01-2009, 20:23
Sykan's Avatar
Lead Programmer
AKA: David
Thank You that helped a bunch. now if i can get the 2d array to sort by area it will be golden.
David Elizondo
(Programmer)
Unread 23-01-2009, 06:49
There is a trick to it.
The vision example for tracking the gimbal does it. There is a VI called something like size ordered morphology, and it asks for all the values, pulls out the sizes, sorts them, then moves the original rows in the same way.
You can use it for a pattern, or you may even be able to use it.
Greg McKaskle
Vision Assistant Sykan NI LabVIEW 1 17-01-2009 16:43
Vision assistant activation help Chath Maral NI LabVIEW 2 15-01-2009 23:14
Problem with vision assistant sagivlev NI LabVIEW 4 11-01-2009 21:48
Axis Camera responding in the Vision Assistant but not in WindRiver DanDon C/C++ 3 11-01-2009 12:50
Assistance in Vision Assistant Carmelulu` NI LabVIEW 1 10-01-2009 15:36
