Go to Post This is about more than building a robot, we cannot only do the fun things. If you are fully involved than you will be prepared to do anything in life. - Andy Brockway [more]
Unread 23-01-2009, 14:35
FRC1672's Avatar
FRC1672 FRC1672 is offline
Team 1672
FRC #1672 (Mahwah Robo T-Birds)
FRC1672 is on a distinguished road
Issue with DS DigitalOutput
We were testing our digital output and used the set method from DigitalOutput.ccp
* Set the value of a digital output.
* Set the value of a digital output to either one (true) or zero (false).
void DigitalOutput::Set(UINT32 value)
m_module->SetDIO(m_channel, value);
we used:
set(0)
and set(1)
both gave us issues while building and compiling.
* Create an instance of a digital output.
* Create an instance of a digital output given a slot and channel.
DigitalOutput:igitalOutput(UINT32 slot, UINT32 channel)
InitDigitalOutput(slot, channel);
I believe our issue was with creating DigitalOutput object. Which slot and channel should we enter to reference?
Unread 29-01-2009, 11:08
Kruuzr Kruuzr is offline
Mentor - electrical, software
AKA: Steve Cote
FRC #1922 (Ozram)
Kruuzr has a spectacular aura aboutKruuzr has a spectacular aura about
Re: Issue with DS DigitalOutput
Actually, I believe your issue is with case. If you did actually use set(0); and set(1);, the compiler would not recognize the code. You would need to use Set(0); and Set(1); (C/C++ is case sensitive).
Unread 29-01-2009, 11:37
heydowns's Avatar
heydowns heydowns is offline
AKA: Jeff Downs
FRC #1511 (Rolling Thunder)
heydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond repute
Are you trying to change outputs on the cRIO/Robot or on the DS? Your post title said DS.
If that's the case, then you don't want to use the DigitalOutput class. Instead, have a look at the DriverStation class. There are functions in there to set the DS digital outputs.
Issue with Color Tracking Example (C/C++) and with Counters, Encoders, and Ultrasonic BradAMiller Programming 3 19-01-2009 21:24
Interrupt issue with new code EHaskins Programming 6 05-01-2008 00:27
A small issue with our Mecanums AGWSPilot Technical Discussion 15 18-03-2007 02:11
Issue with CMUCam2 Demo application Bio LabView and Data Acquisition 12 21-01-2006 16:08
