Go to Post Team spirit is not all about the tools/noise makers. The Tigertrons didn't have any sort of noise makers. Consider other aspects of the award by making signs, mascots, cheers, and how you interact with other teams. - team222badbrad [more]
Unread 24-01-2009, 21:09
smcmahon's Avatar
smcmahon smcmahon is offline
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
smcmahon is an unknown quantity at this point
Post using a switch/button to turn on a motor
As a novice LabView programmer, I'm going to post this here to see if it's a viable way to code the outcome I'm looking for... which it this:
I have a CIM motor. It's connected to a Jaguar, and then to PWM channel 10 on the digital sidecar in Slot 4. I want to set a speed for this motor in the code (preferably in percentages, like 85%). And then I want to have a switch turn that motor on/off. In the final outcome, I imagine I'll actually have a joystick turn this on/off, but for now, I want to test it with a button on the Front Panel.
I've attached the code I wrote. It's in a while loop, which I am hoping is controlled properly by the ON/OFF switch (Boolean). Does this look like it will work to do what I want?
Unread 24-01-2009, 23:17
Re: using a switch/button to turn on a motor
Unless what you want it to do is cause the code to sit doing nothing but set the fan speed while the "fan on" switch is true, and eventually have the watchdog activate and disable everything, I don't think that code will do what you want.
The easiest way to have a button turn a motor on and off is probably to use a "boolean selector" to choose which of two speed values to send to the motor based on the state of the button. (I don't have a copy of LabVIEW available right now, so I can't provide a picture of a simple example.)
Unread 25-01-2009, 19:35
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
You want a Case Selector.
See attached for both cases. It sets it to 0 if off, else it to the speed control.
ID:	7222  Click image for larger version
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Unread 26-01-2009, 18:42
smcmahon's Avatar
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
Thank you very much whitetiger0990. I'm going to give that a shot. That seems SO simple now. Being so new to LabView though, I hadn't thought of it like that.
Survey: What rate of turn gyros are you using? windell747 Electrical 5 15-02-2008 12:47
Make my motor turn! [RSMT]sturm Programming 6 24-01-2008 07:54
Push Button and Switch Suppliers for OI controls Goldberg204 Control System 8 11-01-2007 15:27
Using a button on a joystick to track? DemonYawgmoth Programming 5 12-02-2006 11:17
push-button switch on robot Conan Electrical 4 10-02-2006 22:03
