i need a camera tracking code not the same one in the frc updates... becuase we tryed it but it has alot of problems ..... plz someone help and put here there code for the camera tracking, also if it has a problems. we just wanna see other examples to chose the better
Re: camera tracking code
I would guess that if you're having a lot of problems with the example code, that it is not the fault of the code itself. Many teams have used it and not had any issues once they understood how to set it up.
If you travel to the First Robotics Labview forum, you will find that several teams have posted their camera code. The Beachbots even have a fully functional vi (in the basic framework) that will drive your robot to the light if you configure it. Other than that, I would suggest that you ask specific questions regarding what is not working so that we can suggest how you can correct your errors in configuring your system. Despite the gracious professionalism on this board, I doubt very many teams will be willing give simply give you camera code that they've worked hard on. |
ok... we have the problem with camera tracking .. and when we search about the panfortarget in the WPILib we don't find any thing .. is it an updates problem?
| Camera locked in "tracking", but not tracking | geeknerd99 | Programming | 1 | 18-02-2007 22:47 |
| Using kevin's code for driving and camera tracking | razzoc | Programming | 3 | 18-02-2007 08:50 |
| camera tracking | geekofband007 | Programming | 15 | 15-02-2007 23:50 |
| Camera Tracking Woes | VideoMan053 | Programming | 4 | 29-01-2005 18:09 |
| Camera Auto Tracking? | Ryan Cumings | Programming | 9 | 22-01-2005 02:20 |
