Go to Post Magic Smoke. One whiff and you never forget. - JohnBoucher [more]
Unread 25-01-2009, 23:09
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Team 1311's Robot Work in Progress
Greetings Teams,
For better or worse, you can see our progress here. Over the next few days more pictures will be added as the sub-assemblies are mounted and maybe it will make more sense.
Or maybe it will make no senses at all, but that is part of the fun !!
work in progress
Ed Barker
Unread 25-01-2009, 23:23
nnfuller's Avatar
nnfuller nnfuller is offline
AKA: Alumni
FRC #2733 (Pigmice)
nnfuller is on a distinguished road
Re: Team 1311's Robot Work in Progress
Nice! looks like a consistent dumper design. Have you thought of making the dumping direction variable, or maybe just try to use a CIM on the brush to speed it up as it dumps?
this all assumes i understand!
Unread 25-01-2009, 23:28
ebarker's Avatar
AKA: Ed Barker
Originally we wanted front, left, and right dump chutes.
what you see should be either front dump chute or top gun shoot, depending on how it is operated.
what you are not seeing is the damper that has to actuate to press the balls against the belt to feed the shoot or reverse acutate to feed the chute.
when the damper plate gets installed it should make a little more sense.
Ed Barker
Unread 25-01-2009, 23:34
nnfuller's Avatar
AKA: Alumni
FRC #2733 (Pigmice)
sounds like you are one step ahead of me! go figure!
pic: Robot in progress Grandma Extra Discussion 1 05-03-2008 11:24
Robot progress team 2191 General Forum 19 06-02-2008 18:58
Team 1652 Work in progress DrinkyDrinky Website Design/Showcase 3 14-01-2008 21:15
Team 75 Work in Progress gliebowitz Website Design/Showcase 11 03-03-2003 15:22
