WindRiver errors
Okay, I have been fighting with the cRIO for weeks now. I have already configured the whole system and at one point was able to make a motor run using the default code in WindRiver but now I am unable to get the downloaded code on to the cRIO. The driver station sometimes says next to the battery label that there is "no code" while sometimes it displays the battery voltage. The program seems to be compiled and the IP addresses are all connected. Does anyone have any idea how to download the code?
Also, I have been using the Simple Template with the MyRobot.cpp file to learn the WindRiver language but how would I go about making a new template of which I can have the base as the Simple Template but I can edit it and add other ".h" files and templates (such as gyro or camera) into it? Hopefully my question is clear. I would greatly appreciate any help. Thank you. |
Re: WindRiver errors
I think you may need to update the cRIO: LINK
Select the link that says LabVIEW FRC software update, install it, and re-image your cRIO. I remember getting a "No Code" error with an outdated version |
| WindRiver Errors | ExarKun666 | C/C++ | 7 | 04-03-2009 20:32 |
| Makefile Errors | neutrino15 | Programming | 1 | 29-01-2008 15:45 |
| LINKING ERRORS!!! | AHepperla | Programming | 4 | 19-01-2008 10:00 |
| CAMERA ERRORS!!!!!!!!!!!! | Hershey | Technical Discussion | 0 | 21-01-2005 18:59 |
