Go to Post Another year, another picture of a Tytus injury. - Andy Baker [more]
Unread 28-01-2009, 11:53
nadavsen2 nadavsen2 is offline
FRC #2231
nadavsen2 is an unknown quantity at this point
Connection with cRIO
I want to build a nice console and to get the joystick's values,Gyro's value
and so on .How i connect myself to the cRIO NOT from windriver?
I mean from another software , can i get those values from ip and port?
Unread 28-01-2009, 14:49
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: Connection with cRIO
You can either connect via the serial port on the cRio, or use the dashboard data and the labview dashboard app to display the data.
There are instructions how to configure the serial port for console output in one of the control system documents, but I don't remember which one.
There is an example of how the send the dashboard data in the Wind River samples, but you would need to modify the labview dashboard to work with your data.
Eric Haskins KC9JVH
Unread 28-01-2009, 17:47
FRC #2231
im not working with LabView so i want to make an alternative to it by myself.
Can anyone direct me to some guides or documents?i searched in usfirst...
Unread 28-01-2009, 19:49
AKA: Eric Haskins
I'm not aware of any official documents, but I was able to decode the dashboard data from a .net program. I'm working on a white paper and dashboard viewer, but they aren't ready for humans to view.
If you want me to send you the current draft of my documentation send me a PM or e-mail (public [at] ehaskins [dot] net), and I'll send you a copy.
Eric Haskins KC9JVH
Unread 29-01-2009, 03:13
FRC #2231
i sent you an Email , if you didnt get it , send it to "nadavsen2@gmail.com"
thanks alot
cRIO configuration issue- serial connection to laptop Torbots 1197 FRC Control System 5 28-01-2009 22:28
Bluetooth with cRIO/DS? hellochar Programming 3 22-01-2009 17:20
cRio losing connection when "run as startup" mgurgol Programming 2 12-01-2009 12:18
problem with connection seanl Programming 1 29-01-2007 10:41
Teams with an ASME Connection Wanted for Publicity Vince General Forum 0 18-06-2002 12:24
