WindRiver Parallels
Hi all,
I am using Parallels on my MacBook to program our robot and am running into some problems. We attached the DS directly to the cRIO and I am now testing the system. When the original code was on the robot, it worked fine. However, I tried to write the SimpleRobot code to the cRIO and have had problems ever since. Now, the cRIO won't accept the imaging tool or WindRiver programming, and the DS shows "Battery: No Code" on the LCD. I have Parallels set up in Ethernet bridge mode with IP address 10.0.95.6. However, when I run FIRST->Download in WindRiver, it waits on Downloading Robot... for a while and then complains that it can't find 10.00.95.2/21. Is this a known problem? In case more information is useful, I am running the ethernet port out of the macbook into ETH2 on the DS and ETH1 on the DS into ETH1 on the cRIO with two normal (non-crossover) cables. The MacBook is auto-sensing and the DS is auto-sensing, so that shouldn't be a problem. Thanks in advance for the help! nick |
Re: WindRiver Parallels
Well, it turns out that it isn't a problem with Parallels. I tried on a Windows machine, and the same problem was present -- it "saw" the cRIO with IP address 10.0.95.2 and then tried, but failed to located it for updating the image. Any tips?
| WindRiver Errors | ExarKun666 | C/C++ | 7 | 04-03-2009 20:32 |
| WindRiver Programming | dnrobotics11 | C/C++ | 1 | 19-01-2009 20:13 |
| WindRiver Programming | dnrobotics11 | C/C++ | 4 | 19-01-2009 19:43 |
| EasyC 2.0 on parallels vs vmware fusion (vs wine?) | neutrino15 | Programming | 3 | 27-09-2007 00:12 |
