Go to Post When you're in a field as deep as the Championship go offensive or go home. It's that simple. - thefro526 [more]
Unread 28-01-2009, 16:42
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Switch digital input to output during operation? Parallax Ultrasonic
I have been trying to run a ultrasonic sensoic sensor, but I keep getting a result of ~.045653 no matter what I do. The light on the sensor blinks every time it pings, but I do not get any feedback.
Will the ultrasonic class work with the Parallax Ping Ultrasonic Sensor, or will it cause issues because there is only one in/out on the sensor? If not would it be possible to set a digital output to a digital input during operation?
Thank you
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 28-01-2009, 19:11
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Switch digital input to output during operation? Parallax Ultrasonic
The Ultrasonic class is designed to work with the Daventech SRF04 (or Vex) rangefinders. You can also use the Maxbotix sensors with analog outputs then just convert the voltage to distance.
Using one of the one wire ultrasonic sensors where you have to switch an input to an output is not recommended.
Brad Miller
Robotics Resource Center
Unread 28-01-2009, 19:30
wt200999's Avatar
Texas Instruments
AKA: Will Toth
I recall last year we were able to wire the one header on the parallax ultrasonic rangefinder to two headers on the old controllers and that worked. That wont work this year either?
Parallax and Maxbotix ultrasonic sensors Lucretius Programming 5 20-02-2008 14:34
Programming the parallax PING))) Ultrasonic Sensor edman Programming 3 18-02-2006 23:37
Programming Parallax Ultrasonic Rangefinder edman Programming 2 17-02-2006 08:35
Ultrasonic Sensor output Dillon Compton Programming 5 03-02-2006 10:20
Using a switch before autonomous operation KZos550 Programming 11 04-02-2003 19:12
