Go to Post However, I do expect something truthful to come out of some of Dave's posts. - Karibou [more]
Unread 29-01-2009, 22:02
Chief Pride's Avatar
Chief Pride Chief Pride is offline
<3
AKA: James Kiefer
Chief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond repute
Servo's won't power up...
I have been trying to get these servos on the camera gimbals to move for quite some time, but I cant even manage to get them power... The jumper is in place, on 9 and 10 in the PWM outputs, however, the servo's aren't moving, not even centering when the robot is turned on. I have used both the TwoColorDemo and made my own routine to move the servo's, but nothing...
Any ideas?
Unread 30-01-2009, 01:02
Redneck's Avatar
Redneck Redneck is offline
Hacker Hick
AKA: Jamie (2.0) Moran
FRC #0599 (Robodox)
Redneck is just really niceRedneck is just really niceRedneck is just really niceRedneck is just really nice
Send a message via AIM to Redneck
Re: Servo's won't power up...
We need some more info.
1)Do other things on the robot work (e.g. can you control speed controllers with the PWM outputs?)
2)Can you show us the routine you tried?
3)How's your cRIO set up, specifically are you using one or two of the digital modules/sidecars?
Which badges can you claim?
Unread 30-01-2009, 08:18
<3
AKA: James Kiefer
Yes, motors work with the jaguars and PWM's.
I am using the default TwoColorDemo code without any changes.
We are using 1 sidecar, however, I did switch them out to see if one was faulty, and it wasnt.
Thanks again.
Unread 30-01-2009, 18:00
Redneck's Avatar
Hacker Hick
FRC #0599 (Robodox)
Ok then, couple more diagnostic questions -
1)When you power on the robot, does the Driver Station display "No Code" where it should have battery voltage?
2)Have you tried connecting a serial cable between the cRIO and your computer to get a console? If you haven't yet, try that and see if any errors come up.
Unread 31-01-2009, 09:20
<3
AKA: James Kiefer
No, it shows battery voltage. I will connect to the serial port now and post my findings.
Unread 01-02-2009, 10:52
<3
AKA: James Kiefer
Finally found the problem, someone had clamped down too far on the ground wire powering the DSC, causing it to not have connection. All is well after fixing the connection.
[FTC]: Do Servo's reset during start up? ttldomination FIRST Tech Challenge 16 27-01-2009 18:25
Camera won't initialize when reset from RC - reset from OI and Power-up works, krunal Programming 7 15-01-2007 00:13
In a Pickle: Servo's stay at 127 vector023 Programming 11 14-02-2006 17:54
EDU won't power up. actorindp Robotics Education and Curriculum 4 12-02-2004 22:20
Servo's and EduBots? DanL Motors 6 13-01-2003 10:11
