Go to Post Gotta love the use of universal technical terms, along with whatchamacallit, doodlespiel, whosiwhatsit... ;) - PaW [more]
Unread 30-01-2009, 10:18
boris boris is offline
FRC #2626
boris is an unknown quantity at this point
Unhappy cRIO loses code on reboot?
Yesterday my cRIO started acting really weird. We undeployed the code with windriver, we rebooted the cRIO, we Downloaded the code and then we Rebooted again... The driver station displayed "NoCode". The transfer or undeploying didn't give me any error.
We did the updates for everything, we set the team number and it still gave me the same thing.
We might have a problem with the code or the connection.
Can you give me any way of troubleshooting all this mess?
Basically what should I look for?
Unread 30-01-2009, 10:42
FRC #2626
Re: cRIO loses code on reboot?
IT WORKED I FOUND OUT!!!
my code was misbehaving because I didn't use static variables properly...
Issue with debugging/running code on cRio 114Klaatu0x72 Programming 5 27-01-2009 14:02
cRIO has no code 2roy999 C/C++ 7 19-01-2009 02:01
Run Kernel Task w/o reboot byteit101 Programming 4 12-01-2009 12:08
cRIO - motor controller code (esp. victor) ericand Programming 8 06-12-2008 22:09
FIRST looses even more ground in the war for TV fame?? archiver 2000 4 23-06-2002 23:53
