Go to Post Welcome to FIRST! It's in your blood now... - AmyPrib [more]
Unread 30-01-2009, 10:20
Mazin Mazin is offline
FRC #1720
Mazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to all
Send a message via AIM to Mazin
2009 AVA: Are you working hard?
GUYS! I had this really freaky dream that the AVA was due February 5th! Freaked me out.
In other news, here's a little scene I cooked up of the rare Wild Utah Teapot in its natural habitat. As you can see, it's a bright sunny mental ray day, which brings me to my actual topic.
I highly recommend considering selecting the mental ray renderer as your production renderer. It used to be that you had to shell out additional $$$ for finalRender or Vray to have an alternative to the obsoleting 3ds Max scanline renderer, but not since 3ds Max 6. Not only will mental ray probably render your existing scenes faster, but also offers many, many more advanced features and tweaks.
Check out the above picture. Mental ray features include one-pass depth of field, fast SSS-like shader, and and fast GI calculations. The render time was about 4 minutes, with about 200k triangles.
Unread 30-01-2009, 11:19
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Re: 2009 AVA: Are you working hard?
Rendered 700 frames in 3d Studio Max to BMP frames. Edited said frames in Photoshop. Deleting any evidence that the field is for last year's game. Added Paint Daub filter to frames and applied diodes to dancing student and then cropped pictures so he wouldn't be obviously seen dancing at the side of the field where he would be disqualified in real life.
Now to do the other half of the animation.....
Unread 30-01-2009, 11:29
FRC #1720
Almost +faved that. BMP is a good way to waste disk space.
Unread 30-01-2009, 11:38
Koko Ed's Avatar
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
It's stored (twice) on a server.
Unread 30-01-2009, 11:44
FRC #1720
Yes but the sheer size of them chokes disk I/O. If they were stored locally, consider an average disk throughput of 20 MB/s. If each image is about 2 MB (2,000 kB), then you can read about 10 images a second, or less than half of a normal framerate. If they were stored on a server, as you say, consider a server throughput of 100 Mbps LAN - network overhead, so maybe 8 or 9 MB/s, and wonder why Premiere takes so long to load the files.
Also, consider this thread derailed.
Unread 30-01-2009, 11:50
Koko Ed's Avatar
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Someone else will come get it back on track.
We're trying to make it worse by uploading Inventor files into the animation.
Now that will kill the program's ability to run well (did it before back in 2004 with very unhappy results. The model kept pulling itself apart and it was the last night before it was due so we didn't have much time to play with it so we had to live with it's flaws).
Unread 30-01-2009, 22:32
FRC #1720
At the risk of turning this into a general help thread, how exactly are you importing Inventor models?
Unread 31-01-2009, 08:29
Koko Ed's Avatar
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
I use the method 3D Studio Max recommends.
File menu > Import > Select File To Import dialog > Files Of Type > Autodesk Inventor (*.IPT, *.IAM)
Unread 31-01-2009, 08:42
BuddyB309's Avatar
BuddyB309 BuddyB309 is offline
I freaking love animating!!
AKA: Peter Casey
FRC #1625 (Winnovation)
Team Role: Animator
BuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond repute
Send a message via AIM to BuddyB309
I always avoid importing inventor files. the poly cont is always through the roof.
A.K.A Llama
check out my latest animations Appliance Night Out, Infant Intolerable, Fishing Like a Loony Tune, VVV Roadside Assistance
Life? I have a life. It is sitting at my computer and Animating. AND DRAWING!!! WEEEEEEE!!!!
Unread 01-02-2009, 21:24
FRC #1720
Yes but the quality of the meshes generated by that method of import is unmatched.
Unread 30-01-2009, 13:35
MadeAtMidnight's Avatar
MadeAtMidnight MadeAtMidnight is offline
AKA: Carrie Asner
MadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud of
Nice! Would like to see the other half when done
Carrie
League of Mothers founding member
"There are two ways to spread light; to be the candle, or the mirror that reflects it."
Edith Wharton
Unread 30-01-2009, 13:58
BuddyB309's Avatar
AKA: Peter Casey
Team Role: Animator
You guys are getting this rendering thing completely wrong. Don't render out in .bmp files. Render out in .tga or .png files. That way they have an alpha channel and you can composite layer rendering. As soon as your shot is done rendering, take the image sequence folder and make after effects or premier turn them into .mov files with the animation codec. Still no quality loss and they all still have alpha channels.
Either way, if you don't want quality loss your going to end up with a ton of data. Appliance Night Out took up 100 GB on my computer before I could crunch it down.
A.K.A Llama
2009 AVA Criteria lilwupster 3D Animation and Competition 2 08-01-2009 12:04
pic: Adults Working Hard IndySam Extra Discussion 18 09-04-2008 19:22
pic: Big Mike Working Hard Mike Schroeder Extra Discussion 24 30-11-2007 03:56
pic: Working Hard, As Always CD47-Bot Extra Discussion 4 14-04-2003 09:07
Are you hard core or not? Joe Johnson Championship Event 7 25-04-2002 23:05
