Go to Post Don't let the teams here be so much of an intimidation to you, but instead, an inspiration. They all had to start from the beginning, too. - Amanda Morrison [more]
Unread 30-01-2009, 13:47
boris boris is offline
FRC #2626
boris is an unknown quantity at this point
Digital Input?
I made myself an digital input object to use with a limit switch.
The channel et cRIO slot are set properly but I don't have a clue on how to get the value from the digital input...
Unread 30-01-2009, 14:51
heydowns's Avatar
heydowns heydowns is offline
AKA: Jeff Downs
FRC #1511 (Rolling Thunder)
heydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond repute
Re: Digital Input?
To read the value of the DigitalInput object, you can call the Get() member function.
This was undocumented up to and including update 2 - not sure if that's been fixed in update 3.
In general, WPILib has some undocumented functions and types currently -- look at the header file for the class (DigitalInput.h) in this case to see the complete interface. If using the example template to build your program, the headers can be easily found under the Include node in the files tree.
Digital Input Power AHepperla Electrical 5 15-02-2008 15:34
Auton digital input ten3brousone Programming 7 20-03-2005 22:23
digital input question... Kevin Karan Programming 9 12-04-2004 07:34
counting digital input CharlieWilken Programming 9 22-03-2004 19:56
Robot Digital Input Mike Norton Technical Discussion 5 16-01-2003 14:31
