Go to Post If that track ball comes crashing into Exploding Bacon's robot there is literally going to be an Oink Oink BOOM!:yikes: - Koko Ed [more]
Unread 30-01-2009, 14:17
Stephen Green Stephen Green is offline
FRC #0069
Stephen Green is an unknown quantity at this point
Unable to Add .h File to Project
We have created a new class in a .cpp file and have placed the declarations in a .h file. We can import the .cpp file to the project PPC603gnu subdirectory but cannot import, copy/paste or drag-and-drop the .h file into the include subdirectory. Are we attempting to place the file in the appropriate locations and how do we add .h files to the project/
Unread 30-01-2009, 15:21
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
Re: Unable to Add .h File to Project
If you want to add a new include path, right-click on your project and select Properties. Select Build Properties and then Build Paths. Add a path to a directory holding all of your .h files.
The easier way would be to just add the .h files in the same way the .cpp files were imported.
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
How to use the data obtain in one C file to another C file? tommy_chai Programming 8 11-01-2008 02:17
Help! making an inventor file into an autodesk file kjhobin Inventor 5 19-03-2006 23:04
Legal to add .c file? Doogie Programming 8 13-10-2005 17:03
How do we convert a modified user routines file into a valid .HEX file HuskieRobotics Programming 13 28-02-2004 12:12
Project Template File Jon Abad General Forum 1 12-01-2002 18:04
