Go to Post To give credit where credits due, thanks to the GDC for this update. - Brandon Holley [more]
Thread Tools Rating: Thread Rating: 5 votes, 4.80 average. Display Modes
Unread 31-01-2009, 15:31
NinJA999's Avatar
NinJA999 NinJA999 is offline
Chipmunk NinJA
AKA: Nick Aldwin
FRC #0811 (Team 811)
NinJA999 will become famous soon enough
Send a message via AIM to NinJA999
CHM help files error?
Hi,
Any time I attempt to open the .chm files provided by WPI -
CPPReference.chm
and
NIVisionCVI.chm
I get the following error:
 Action canceled
Internet Explorer was unable to link to the Web page you requested. The page might be temporarily unavailable.
Please try the following:
Click the  Refresh button, or try again later.
If you have visited this page previously and you want to view what has been stored on your computer, click File, and then click Work Offline.
For information about offline browsing with Internet Explorer, click the Help menu, and then click Contents and Index.
Internet Explorer
then, on attempting to browse to any pages, I get
The page cannot be displayed
The page you are looking for is currently unavailable. The Web site might be experiencing technical difficulties, or you may need to adjust your browser settings.
If you typed the page address in the Address bar, make sure that it is spelled correctly.
To check your connection settings, click the Tools menu, and then click Internet Options. On the Connections tab, click Settings. The settings should match those provided by your local area network (LAN) administrator or Internet service provider (ISP).
See if your Internet connection settings are being detected. You can set Microsoft Windows to examine your network and automatically discover network connection settings (if your network administrator has enabled this setting).
Click the Tools menu, and then click Internet Options.
On the Connections tab, click LAN Settings.
Select Automatically detect settings, and then click OK.
Some sites require 128-bit connection security. Click the Help menu and then click About Internet Explorer to determine what strength security you have installed.
If you are trying to reach a secure site, make sure your Security settings can support it. Click the Tools menu, and then click Internet Options. On the Advanced tab, scroll to the Security section and check settings for SSL 2.0, SSL 3.0, TLS 1.0, PCT 1.0.
Click the  Back button to try another link.
Cannot find server or DNS Error
Internet Explorer
So I am unable to use the WPI help files. Has anyone else had this problem? Have you figured out a solution?
Team 811 (Nashua, NH) - Mentor
Previously Team Lead & Programming Lead
Unread 01-02-2009, 01:59
omalleyj omalleyj is offline
AKA: Jim O'Malley
FRC #1279 (Cold Fusion)
omalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to behold
Re: CHM help files error?
I forget where it is documented, but this is a permissions issue. Open the file properties and it will say something about the file being from another system and a check box to allow it to run. Unblock I think. There is a Microsoft knowledge base article about it if you want the details.
WPI Programming Reference Guide CHM? R.C. FRC Control System 2 10-01-2009 14:08
WPILib C++ CHM Documentation jtdowney Programming 0 05-12-2008 14:12
180:Error: syntax error help! seanl Programming 8 04-02-2007 11:31
Help with Files tawnos484 Programming 4 20-01-2006 03:40
CAD Help needed. Mech Desktop 6 files backwards to AutoCAD 14? (2d files) Elgin Clock Inventor 0 30-08-2004 23:06
