Go to Post A lot of people forget this when posting, but your posts here on ChiefDelphi will more or less be here forever. Do you really want that post you just be made to be on the Internet forever?... Post wisely... - artdutra04 [more]
Unread 31-01-2009, 19:24
pinballwizard96's Avatar
pinballwizard96 pinballwizard96 is offline
Ludologist, audiophile, etc
FRC #3021 (The Caiman Agents)
pinballwizard96 is an unknown quantity at this point
Non-Arcade Drive causes problems in Autonomous...
I deployed the default FRC cRIO project correctly and noticed that both drive motors were now controlled by one joystick. When I switched to Autonomous mode, the default program ran as expected EXCEPT...only 1 motor changed directions - the other one ran in the same direction for the duration of the program. I tried switching the connectors, and the OTHER motor experienced the problem while the 1st one corrected itself. Could this be related to the speed controller, or is the autonomous program intended to switch the direction of only 1 motor?
Thanks in advance
pinballwizard96
"The Enrichment Center is committed to the well being of all participants. Cake and grief counseling will be available at the conclusion of the test. Thank you for helping us help you help us all." -Portal
http://www.youtube.com/watch?v=VnqpOFcBiMM
Unread 01-02-2009, 10:01
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Re: Non-Arcade Drive causes problems in Autonomous...
The default code is set to Arcade drive. This means that the robot is controlled by one joystick. The y-axis controls velocity, the x controls rotation.
I don't have the autonomous code in front of me, but from what I remember with playing around with it was that your description is correct. The default autonomous code is on a timer, and goes forward then turns (left I believe) for a short amount of time four times.
To me, it sounds like the default code is running perfectly fine. To switch to tank drive (two joysticks, each controlling one side of the robot), you will have to replace the Arcade drive VI with the tank drive VI, and add another joystick. You can also easily change the autonomous code (<A href="http://www.lvmastery.com/tipjar2009-01-02">LV mastery tutorial on autonomous</a>).
If you already modified you code, and it isnt changing anything, make sure your build specifications are correct, and that you are deploying the build to run as startup. If it isnt being run as the startup project, the old code will continue to be run every time you turn the robot on.
Team 2052- Knightkrawler
Mentor and volunteer
Unread 01-02-2009, 20:45
alright I shoulda noticed that...was mainly worried about the autonomous mode because I heard it was supposed to run the robot forward and backwards (they probably had already changed it).
Thanks
pinballwizard96
Adding non drive motors in Advanced Framwork ffej NI LabVIEW 11 01-02-2009 20:12
Arcade/Tank Drive Malfunction piedmont Programming 2 19-01-2009 17:37
Non-camera servos in Autonomous Vashts6583 Programming 8 18-02-2007 12:31
Arcade Drive Anfony VEX 4 08-11-2006 19:46
vex programming arcade drive setting Michael Leicht FIRST Tech Challenge 3 17-10-2005 21:26
