Go to Post And that's why we all need to consider reserving a "No! Bad robot!" button for the robocoach. :yikes: - vhcook [more]
Unread 31-01-2009, 20:30
Electricia 1599's Avatar
Electricia 1599 Electricia 1599 is offline
2nd Solutions E-Cycle Program Head
AKA: Devyn McIver
FRC #1599 (Atlee Robotics)
Electricia 1599 is an unknown quantity at this point
Send a message via AIM to Electricia 1599 Send a message via Yahoo to Electricia 1599
Talking Atlee 1599 ROBOT VIDEOS!!!
Check out our videos and give a comment. We will be at VCU's regional for competition. If anyone has any questions just email me or post it up! this years game is going to be interesting. Cant wait to see everyone there!
Alex
Variable speed test
Ball collector test 1
Unread 31-01-2009, 22:34
MOE's Avatar
MOE MOE is offline
FRC #0088 (TJ2)
Rookie Year: 1995
MOE is a splendid one to beholdMOE is a splendid one to beholdMOE is a splendid one to beholdMOE is a splendid one to beholdMOE is a splendid one to beholdMOE is a splendid one to beholdMOE is a splendid one to behold
Thumbs up Re: Atlee 1599 ROBOT VIDEOS!!!
HELLOOoooo from the North East
Well it looks like you have a good handle on the pick up (looks great). Hope all the other parts a coming along. May we at TJ2 wish you good luck. We will be in VA for our FIRST time "hope we have a HOOT" with our bot. Maybe we will get together, we have a 10-12Hr bus ride ahead Till then good luck and seeeee yaaaaa sooooon
MOE and Team 88 TJ2 oh yeah ???? OH YEAH !!!! TYE DYE for ever....
"Learn skills today with FIRST for tomorrow's JOBS" MOE
Unread 01-02-2009, 10:13
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
Why use ten wheels. IT WILL NOT HELP, it will just add weight.
Unread 01-02-2009, 15:22
AKA: Devyn McIver
it does help a lot actually with steering.
Alex
Unread 09-02-2009, 01:36
caffino54's Avatar
caffino54 caffino54 is offline
El Presidente
AKA: Viraj Sinha
FRC #2367 (The Lancers)
caffino54 is on a distinguished road
Send a message via AIM to caffino54
according to physics, extra wheels won't change anthing becase they will disperse the weight evenly
Unread 09-02-2009, 02:20
dtengineering's Avatar
AKA: Jason Brett
Please note that this is according to your current understanding of physics. The theory that states that surface area is irrelavant when calculating traction is an excellent simplification based on a few reasonable assumptions.
Perhaps the most relevant assumption, in this case, is that the material at the surface contact patch will have sufficient shear strength to handle the forces generated by the friction. Judging from reports of white powder being produced under acelleration, perhaps this is not a reasonable assumption in this situation. Other factors may also be at play... the regolith likely deforms under the normal force of the robot wheels (remember, there is carpet beneath it) and it also fails to present a uniform surface to the wheels. (It is bumpy side up, remember?)
Simplified models merely approximate complex realities. I think I'll believe 1599's empirical evidence over a simplified theoretical prediction!
Jason
Unread 09-02-2009, 04:05
Blackstarr904's Avatar
Blackstarr904 Blackstarr904 is offline
Junior Mentor
FRC #0904 (D3)
Blackstarr904 is an unknown quantity at this point
904 is using 10 wheels as well. 4 in front, 4 in the center, and 2 in the back, all joined together with a chain drive system. Every wheel pushes the bot along... and it DOES really help with steering AND traction.
anyways, looks like you guys are getting there. Good luck from team 904
Unread 09-02-2009, 07:44
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
We were shocked when, in an early brainstorming session with our engineer mentors, they were very supportive of "the more wheels, the better". We sacrificed weight in other areas (no pneumatics, for instance) to allow for 12 powered wheels. The difference between our 4-wheel test chassis and the real one is significant and noticeable.
Unread 09-02-2009, 16:01
AHS1599's Avatar
AHS1599 AHS1599 is offline
Parent/Mentor
FRC #1599 (Techromancers)
Team Role: Parent
AHS1599 is an unknown quantity at this point
It's good to hear that others have found the same positive results that we've seen. We ran another round of tests with our ball collector/ejector mounted and are very happy with the results...
2007 NASA/VCU Regional Semi-finalist
robot 1599 youtube videos Electricia 1599 General Forum 11 31-01-2009 22:55
Team 1599 protype videos on game floor AHS1599 Robot Showcase 8 31-01-2009 14:00
Team 904 robot videos mobilegamer999 General Forum 4 16-02-2008 10:52
DARPA Robot Videos ChuckDickerson Championship Event 14 20-04-2007 16:37
Congrats Team 1599 Athleticgirl389 Thanks and/or Congrats 0 16-03-2007 17:37
