STEP Downloads
When I open STEP files downloaded from AndyMark in Inventor, parts in the assembly appear to be unconstrained. Is it necessary to constrain all of the parts or am I missing something here?
Thanks, Ken S |
Re: STEP Downloads
Need help IM me. |
Re: STEP Downloads
You're not missing anything. The STEP files contain the location of the parts but not the mechanical relationships between them.
If you want your overall assembly to be functional or realistic, it's best to constrain the parts in the STEP file manually. You could also ground all the parts in the assembly as a quick solution (that is, make this a subassembly and ground the parts on the subassembly level), but that's more visual than functional since it still doesn't reflect the actual constraints. |
Re: STEP Downloads
Dan -
Thanks for the info. Is there a global ground commend in Invertor or do you have to ground each part individually? Ken PS 2:58AM??? That is one dedicated roboter |
Re: STEP Downloads
In the SolidWorks assembly, right click in the Feature Manager on the component and select Fix.
If you go to www.3dcontentcentrl.com search for AndyMark. I recreated the AndyMark Chassis by imported the STEP geometry from Andy into a SolidWorks format file through FeatureWorks. These parts are smarter and constrained. Marie |
Re: STEP Downloads
To ground all the parts, just select all of them and check the ground command in the context menu.
#7
Re: STEP Downloads
Yeah, I realized it's been a while since I visited CD, and the zombies in the hallway were too loud for me to sleep... ![]() |
| Vex step-by-step builders' guide | ManicMechanic | VEX | 0 | 14-07-2008 00:12 |
| Downloads | Brdn666 | General Forum | 4 | 05-01-2008 20:22 |
| Hex file downloads | Ryan M. | Control System | 2 | 29-10-2005 19:50 |
| Manual Downloads | Chris_C | General Forum | 3 | 07-01-2002 02:46 |
