Go to Post Now, most of the replies are very tactful when they are questioning a teams' design... but some are simply stupid. Keep your heads. - Andy Baker [more]
Unread 01-02-2009, 14:57
dnrobotics11 dnrobotics11 is offline
FRC #2589
dnrobotics11 is an unknown quantity at this point
Undeploying code. NEED HELP
I have been able to download the Simple Template code on to the cRIO and was able to make a motor run and everything, but when I went to take that code off and put on gyroscope code it would not allow me to undeploy it and WindRiver said "unable to delete UserProgram from the robot". Any new code that I try to download to the cRIO is ignored. What do I do?
Also, how do you print a variable value to the terminal window (for testing purposes) in the C++? Is it with the "PrintF" function? Thank you very much.
Unread 01-02-2009, 16:16
Maxpower57's Avatar
Maxpower57 Maxpower57 is offline
Fabuloso
AKA: Maxwell V.
FRC #2574 (RoboHuskie)
Maxpower57 will become famous soon enoughMaxpower57 will become famous soon enough
Send a message via AIM to Maxpower57
Re: Undeploying code. NEED HELP
Not sure how to help with the first program.
make sure your connected to the cRIO in the "remote Systems" panel.
as for the variables. there are a few ways to do it i think
i use
printf(" Int: %d Float: %f ",myIntVariable, myFloatVariable);
which replaces the %d and %f with an int and a float varriable.
i think you might be able to use the cout<< stream too.
which would look like
cout <<"int: "<<myIntVariavle<<"Float: "<<myFloatVariable;
Unread 01-02-2009, 17:22
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Make sure you change the file that you are uploading to the cRIO through the settings. If you don't manually change it then every time you download code onto it it will look like it hasn't changed.
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 01-02-2009, 18:33
FRC #2589
Thank you both very much.
Need help with code CaseyKasem_1251 Programming 3 18-02-2006 09:39
Need help with code. hawk_11 Programming 6 06-02-2005 13:56
Need help with my code jaywion Programming 9 20-03-2004 11:32
code violation...need help Vince lau Programming 4 20-02-2004 16:31
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
