Go to Post "When I joined the team, I was told that we'd be in the shop for six weeks. I STILL haven't seen a single boutique, and now they have me dumpster diving for robot parts! I quit!" - EricH [more]
Unread 01-02-2009, 22:36
team 2777 team 2777 is offline
FRC #2777
team 2777 is an unknown quantity at this point
Question need help on Isonic® MOD3
we have no instructions on how to wire this to our robot, could some help us. some pics or drawing would be nice
edit, we will be using one for our bot but do not know how to wire this for control of the cylinders, we dont now where to wire it to or how to wire ithttp://www.bimba.com/Products/Mead/Isonic%20MOD3/
Unread 01-02-2009, 22:41
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
Re: need help on Isonic® MOD3
you may need to elaborate more on what you need.
Unread 01-02-2009, 22:43
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Congrats on your FIRST, when posting on delphi make sure to include details of what you need. Also links to a site or pictures makes life easier and getting answers and feedback easier.
R.C.
MadTown Robotics Team 1323
Unread 01-02-2009, 22:48
Andy L's Avatar
FRC #1458
Just trying to give you a quick response, I'm pretty sure you're referring to what is known as the festo solenoid. A post with some good responses can be found at http://www.chiefdelphi.com/forums/sh...Festo+solenoid
Here is a PDF that shows you how to wire it and hook up to tubes.
http://www.festo.com/INetDomino/file...TValveAssy.pdf
That is I'm 90% sure that's a festo solenoid if not then I'm not sure
Unread 01-02-2009, 22:54
I did a quick search for the solenoid valve in question. http://www.mead-usa.com/products/detail.aspx?id=1
Now, here's the lowdown: I can only find that it uses a bus system. It looks like you'll have to make your own.
The really bad news is that unless the website is wrong, I don't think you can use it. <R71> specifies that "All included items must be “off the shelf” pneumatic devices rated by their manufacturers for pressure of at least 125psi," and the largest rating I can find is 120 PSI. <R71-C> also specifies a maximum of 1/8" NPT port diameter, and the product doesn't go that low, according to the specs.
So, you're going to need to really look closely at <R71> and compare your product to that. If it doesn't meet one of the requirements, it won't pass inspection.
Unread 01-02-2009, 22:56
Andy L's Avatar
FRC #1458
Eric appears to have corrected me, I assumed you were using the solenoid from the kit.
Unread 01-02-2009, 23:01
FRC #2777
thanks guys, i got it figured out now, one question now, do you hook this up to your digital side car. if not where?
Unread 01-02-2009, 23:24
Andy L's Avatar
FRC #1458
Pneumatics Bumper
PLEASE HELP!! Need help programming arm?? amirjpl Programming 12 15-03-2007 15:11
need help assembling parts in inventor .. (was: help) jhallel Inventor 5 22-02-2007 01:46
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
