hi this is team 3059, rookie year, and thank you for this chance... we have decided we want to use a pneumatic system to control the lift and tilt of a box to dump the balls on the robot, however we do not understand how to connect the tubing with the brass fittings, then to the regulators, cyliders, etc.... any ideas or pictures will be greatly appreciated. ..... Thank you. - Team 3059
Re: How to hook up the tubing with the brass fittings
In the past, a number of "quick connect fittings" were provided with the kit, which screwed into pneumatic components on one end, and had a tube connection point on the other. Unfortunately, these were not provided this year.
They were along the lines of these: http://www.smcetech.com/CC_host/page...35b76a72552d34 |
| Trouble with the treads in the brass fittings? | CalTeach | General Forum | 2 | 31-01-2007 07:57 |
| How to hook up a Police light on the Robot?? | xur2007 | Technical Discussion | 4 | 13-11-2006 18:27 |
| How do you hook up the camera? | SpeakerSilenced | Programming | 18 | 16-02-2005 15:00 |
| How do u hook up the digital input to the sensor's wires | Fares | Technical Discussion | 2 | 14-02-2003 16:41 |
| how do u hook up things through the fuse panel? | chrisw | Technical Discussion | 9 | 12-01-2002 19:51 |
