Go to Post (psst... what's the difference between a geek and a nerd?) - sonicbhoc [more]
Unread 02-02-2009, 10:30 PM
Shira Shira is offline
FRC #1836
Shira is an unknown quantity at this point
Windriver: include paths and new build targets
I'm having trouble using WindRiver. I want to start figuring out how to implement my ideas for the code but I keep getting hung up on setting up my project in WindRiver.
So far:
I made a new project once and I tried to include WPI.h. I added the right include path but the compiler gave an error saying it couldn't open WPI.h.
At that point I just decided to use the project DefaultRobot and edit the .cpp file there.
But with DefaultRobot I could never find the .out file. I tried adding new build targets but none showed up anywhere at all (I searched the whole computer).
So now I'm just editing a project that I know had all the right include files and a build target already. That works fine for now I guess, but explanations would still be nice.
Unread 02-02-2009, 10:54 PM
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
Re: Windriver: include paths and new build targets
If memory serves me correctly, this is what I did:
  1. Create a new Project using File->New->VxWorks Downloadable Kernel Module.
  2. Enter a name for the project and select Create project in workspace (default). Click Next a couple times, using defaults, until reaching Build Specs.
  3. Enable PPC603gnu, uncheck the other options. Click Finish.
  4. In the Project Explorer, right-click on the new project and select Properties.
  5. Select Build Properties, then the Build Paths tab. Click Add and and enter a new include path: $(WIND_BASE)/target/h/WPIlib
  6. Select the Libraries tab. Click Add and enter $(WIND_BASE)/target/lib/WPILib.a.
  7. Add your own files to the project, and edit as normal.
The .out file should be located at $(WIND_BASE)\workspace\<ProjectName>\PPC603gnu\<Pr ojectName>\Debug\<ProjectName>.out. The downloader should be configured to use this file. That can be done in Window->Preferences->FIRST Downloader.
Also, note that you need to include WPILib.h, not WPI.h. I'm not sure if this was just a mistake in your post or not.
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Unread 02-02-2009, 11:18 PM
FRC #1836
Thanks. I haven't tried that yet but I'll do that during tomorrow's team meeting.
Also, yeah, that was a typo in my post. My include statement was for WPILib.h, not WPI.h
Default Labview Dashboard and Windriver Example Help sircedric4 Programming 7 02-25-2009 01:58 AM
New WindRiver Update Pancake C/C++ 5 01-27-2009 03:31 PM
Need help in c++ and windriver jkjohnson C/C++ 3 01-13-2009 06:50 PM
Build/Mechanical teams after build and integration Bomberofdoom General Forum 1 02-02-2008 01:45 PM
UTC site updated to include tons of statistics and specifics archiver 2001 8 06-24-2002 01:39 AM
