Go to Post However, the skill of calculating things by hand and sketching by hand is something that we should continue to teach the youth (until my netbook can run Inventor :D) - Zach O [more]
Unread 03-02-2009, 10:41
Japper's Avatar
Japper Japper is offline
FRC #3692 (RocknRobots)
Japper has a spectacular aura aboutJapper has a spectacular aura about
Multiple Robot Signal lights?
I posted this on the US FIRST Q&A but have not seen a response from the GDC yet...
This year our robot is going to resemble a certain animal (part of our team motif) and the head portion where our moon rock shooter is situated will rotate. We would like to place two signal lights on the head to resemble eyes. One of these would be visible at all times from the front as the head rotates but I did not see anything in the rule book disallowing the use of two signal lights this year.
Has anyone seen a ruling on this?
Thanks
Unread 03-02-2009, 10:55
Re: Multiple Robot Signal lights?
Regardless of what rulings are made, you can only safely power one RSL per DSC. If you attach two, you will run the risk of drawing too much current and having the current limiter shut down the circuit. This would shut off the RSL, which could lead people to believe the robot is disabled when it is enabled.
No damage to the robot will occur, but it is an unsafe situation.
If the GDC allows you to have two RSLs (foshizzle), you must use two DSCs.
Unread 14-02-2009, 13:12
BHOP BHOP is offline
FRC #0399 (Eagle Robotics)
BHOP has much to be proud ofBHOP has much to be proud ofBHOP has much to be proud ofBHOP has much to be proud ofBHOP has much to be proud ofBHOP has much to be proud ofBHOP has much to be proud ofBHOP has much to be proud of
but the problem is the rsl signal only goes through slot 4 right
BHOP
ME CoE University of Michigan
503 Frog Force 830 Rat Pack
399 Eagle Robotics
Unread 14-02-2009, 15:22
http://forums.usfirst.org/showthread.php?t=11749
I would guess that another slot also gets the RSL signal, but I'm not sure which one.
Robot Signal Light smcmahon Electrical 20 08-03-2009 18:11
Whats the Robot Signal light for? steve d Electrical 12 20-02-2007 08:29
Robot signal light 11Mort11 Regional Competitions 11 19-02-2007 10:46
PIC Signal to Robot Controller Pin Map Kevin Watson Programming 2 20-01-2006 18:32
Another team's robot signal not working zeep25 Control System 2 25-02-2004 23:33
