Go to Post And if in the end the students are inspired and more of the public becomes aware of the program, and people gain more appreciation for engineering, how can that not be a good thing? - dlavery [more]
Unread 05-02-2009, 20:42
koka230 koka230 is offline
AKA: Scooter
FRC #0388 (Maximum Oz)
koka230 is an unknown quantity at this point
Send a message via MSN to koka230
pneumatic problem
well we have a shooter on our robot that is pneumatic well when we tested it before, we just put the system up to 60 psi without a regulator instead of having 120 in the tanks and regulated down to 60 just to test it, well when we tested it that way the ball shooter worked but when we put 120 in the tanks and regulated it down to 60 psi it did not work, oh and by the way we have 3/4 with 6in stroke cylinder and we are not getting the speed we need
please help and give some insight on this problem
Unread 05-02-2009, 20:55
robert.hatchett's Avatar
robert.hatchett robert.hatchett is offline
FRC #1262 (STAGGS)
robert.hatchett is just really nicerobert.hatchett is just really nicerobert.hatchett is just really nicerobert.hatchett is just really nice
Re: pneumatic problem
Sounds like the stored air is not able to pass through the regulator at the speed your unregulated test was able to provide.
This is a function of Cv through the regulator.
Unfortunately, since you are required to use the KoP regulator you may have to rework your design to compensate. Also unfortunately, there is no easy solution to this and may require a revisit to your design.
If you could post more details about your system, perhaps there might be more insightful answers to your problem.
Robert Hatchett
Mechanical Engineer
Team 1262 Mentor
Unread 05-02-2009, 21:08
Joe G.'s Avatar
Joe G. Joe G. is online now
AKA: Josepher
no team (Formerly 1687, 5400)
One possible solution would be to put accumulators on the 60psi side of the system. This would result in the momentary pressure drop on the 60psi side to be less, keeping pressure in the cylinder high throughout the cylinder's firing.
Unread 05-02-2009, 21:37
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Robert is correct. The Cv of the regulator is an issue if you are going to try and launch pneumatically.
I would suggest using 2 accumulators upstream of the regulator (120 PSI side) and 2 accumulators downstream of the regulator (60 PSI side). That may give you enough capacity to both shoot and recover quickly.
___________________
- Tennyson, Ulysses
Unread 05-02-2009, 22:00
AKA: Scooter
recovery isn't the issue its just the shooting speed
Unread 05-02-2009, 22:09
Joe G.'s Avatar
AKA: Josepher
Shooting speed would be increased, though, if pressure in the cylinder was high throughout the entire stroke. The more storage space there is on the 60psi side, the less the pressure will go down as the cylinder moves, and the faster the cylinder will move throughout the entire stroke.
Unread 05-02-2009, 22:45
AKA: Scooter
is it possible for us to get a different cylinder will that help too
Unread 06-02-2009, 00:14
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
if there is a way for you to keep the rod end of the cylinder open (do not route the tube to the solenoid), your cylinder will extend much quicker.
with the cylinder plumbed to a double acting solenoid, the vent air (when you extend the cylinder) is restricted through the solenoid.
There are a few ways to do this from a system standpoint.
You can T in a line from the rod end of the cylinder. When you activate the "extend solenoid", also activitate this second solenoid, which is completely vented to atmosphere. When you want to pressurize the rod end of the cylinder to retract, close this solenoid so that the pressurized air on the rod end of the cylinder will cause it to retract.
The other option is to just let the rod end vent. You will get a very fast extension, When you release the pressure after firing, then small bungee cords can full the cylinder back. You can get these little cords at most hardware stores (they are like 1/8" diameter and 6"long).
I am guessing when you did your first testing, you did not have a closed system, so the air could easily exit the cylinder when you extended it.
ID:	7335  Click image for larger version
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 06-02-2009, 02:01
spazdemon548's Avatar
spazdemon548 spazdemon548 is offline
FRC #0548
spazdemon548 has a spectacular aura aboutspazdemon548 has a spectacular aura about
As mentioned above, the easiest solution is to transfer one or two of your accumulators to your 60 psi side. When doing this, try to keep this accumulator as close to the cylinder and solenoid as possible as to decrease your tubing runs. Tubing length does not have as large of an effect on the velocity as the tubing's cross-sectional area will, but it still makes a difference. You may also want to try doubling up on solenoids. I remember seeing a few teams do this last year.
Also, we have found that putting some light oil on the cylinder will help tremendously.
Hopefully you'll find something to work.
[FTC]: Problem with Code or Problem with Bluetooth? VeedotJaydot FIRST Tech Challenge 3 27-01-2009 18:22
Pneumatic Coding Problem lasoaaro Pneumatics 11 18-02-2005 12:11
Pneumatic Claw cvhsrobotics Technical Discussion 10 17-01-2005 23:26
Pneumatic Confusion Cyberguy34000 Pneumatics 10 13-01-2005 02:01
Pneumatic Connectors. Josh Hambright Pneumatics 3 22-01-2003 20:22
