Go to Post Don't let the teams here be so much of an intimidation to you, but instead, an inspiration. They all had to start from the beginning, too. - Amanda Morrison [more]
View Poll Results: What do you think the size of the regionals are going to be in the quest for 5 points
Regionals will be larger 29 65.91%
Regionals will stay the same 11 25.00%
Regionals will be smaller 4 9.09%
Voters: 44. You may not vote on this poll
Unread 28-09-2001, 19:46
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Smaller Nationals = Bigger Regionals?
Since the Nats are going to be considerably smaller this year do you think that the regionals are going to be larger? I know my team is thinking about attending more than one regional this year. I know this is the norm for a lot of teams but it is do you think that more teams are going to attend more than one regionals this year in order to qualify for Nats?
FIRST has to realise that by making the Nats smaller, it does not necessarily solve all thier problems!
Unread 12-05-2010, 08:48
Durza16's Avatar
Durza16 Durza16 is offline
FRC #2062 (C.O.R.E.)
Team Role: Electrical
Durza16 is on a distinguished road
Re: Smaller Nationals = Bigger Regionals?
I think that the regionals will be getting larger, that s the only way that i can think that the Nationals will be smaller.
www.core2062.com
Unread 12-05-2010, 09:12
I think this might be a record for thread resurrection.
There have been nine FRC seasons since Elgin asked the question. We've seen the transition from "Nationals" in the Epcot parking lot to the FIRST Championship in huge sports arenas. Regional competitions have increased greatly in number, if not in size.
I believe this year's push toward more matches for each team was the right thing to do, and it shows that larger competitions are not necessarily a good thing.
Unread 12-05-2010, 12:34
Data Nerd
FRC #0079
Well, since this thing has been raised from the grave already and is craving brains I will give it some of mine. Yay Zombie Thread.
I am not sure if a smaller Championship would lead to bigger regionals but I know that smaller regionals lead to a bigger Championship. The min size of CMP is equal to 7*Regionals (4 champions, 1 EI, 1 CA, 1 Rookie).
This means that for a number of teams N there must N/40 regionals. (I am going to pick 40 as a size since it is FiM's size) or 43 regionals. This means the minimum size of CMP is 301. Now, if we decrease the size to 30 that number grows significantly to 397. This also assumes that all teams go to 1 regional and ignores 2 tier systems like FiM.
Using that logic (more smaller regionals creates a larger CMP) we can actually see that the converse must be true. If I cap CMP at 200 teams (4 divisions of 50) it means there can be at most 200/7 (28) regionals meaning we would have to have 1700/28 (61) teams at each regional. Also we can see that, as FRC gets bigger, regionals must scale linearly with team number.
Unread 12-05-2010, 13:26
Originally Posted by Andrew Schreiber View Post
...for a number of teams N there must N/40 regionals...
You have an unstated assumption regarding the number of matches played at a regional. If you're going to do a mathematical treatment, you need to make that assumption explicit. Better yet, derive it based on more basic parameters like the duration of the regional, the average time between matches, the number of teams playing each match, etc. The average time between matches depends in turn on match duration, field reset and robot synch time...and the number of fields being used. I think the 2006 Greater Toronto Regional was doing about four minutes between match starts, alternating between two fields so one match could be setting up while another was still underway.
Unread 12-05-2010, 13:31
Data Nerd
FRC #0079
Good points, I'll redo the calculations tonight when I have more time. Thanks.
Unread 12-05-2010, 13:37
Chris is me's Avatar
AKA: Pinecone
I read this thread and got scared that FIRST made an announcement about a smaller Championship...
Unread 12-05-2010, 16:51
Chexposito's Avatar
Chexposito Chexposito is offline
AKA: Expo
FRC #1730
Chexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of light
who says nationals will be smaller?
Unread 12-05-2010, 16:54
ATannahill ATannahill is offline
AKA: Alex Tannahill
It was an announcement made back in 2001, do you not remember?
- Arizona North
Unread 12-05-2010, 17:48
Justin Montois's Avatar
Justin Montois Justin Montois is offline
FirstUpdatesNow.com
FRC #3015 (Ranger Robotics)
Justin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond repute
Send a message via AIM to Justin Montois
I've always felt that the Championship event should have more of an IRI field of teams. I understand that the Championship event is an amazing experience and to 'punish' teams that struggle to build even a robot that runs isn't fair but I wish the Championship event was the best of the best.
Give teams something to strive for. Do some kids in college football play 4 years without ever playing in a bowl game, yup. And yeah that kinda sucks but I think our Championship event should have the best teams in the world, not just the teams that can afford it.
I'm not trying to be rude to the teams that were there and didn't have great seasons but let's be honest, there were teams there that didn't win a match at their regionals. That to me is a sign the system is a bit flawed. I'll be the first one to say that our robot probably didn't deserve to be at the Championship Event a couple years if it weren't for Chairmans. IDK i'm just thinking out loud.
@jmontois340
Team 3015
2016- World Championship Finalists and Tesla Division Champions with 2056, 1690 and 1405
2016- Greater Pittsburgh Regional Chairman's Award
2016- Pittsburgh Regional Finalists with 1023 and 4050
2015- Newton Division Finalists With 195 and 1756
2015- Finger Lakes Regional Champions with 4039 and 378
Unread 12-05-2010, 18:56
kjolana1124's Avatar
kjolana1124 kjolana1124 is offline
AKA: Kelsey Jo Starr
FRC #1124 (The ÜberBots)
kjolana1124 has a brilliant futurekjolana1124 has a brilliant futurekjolana1124 has a brilliant futurekjolana1124 has a brilliant futurekjolana1124 has a brilliant futurekjolana1124 has a brilliant futurekjolana1124 has a brilliant futurekjolana1124 has a brilliant futurekjolana1124 has a brilliant futurekjolana1124 has a brilliant futurekjolana1124 has a brilliant future
I have to agree here. As I recall they're going to begin cutting back on the amount of "automatic" spots allowed. I'm for this. Well, sort of.
In 2009, our team didn't even make eliminations during Hartford. We still went to Atlanta. It was an amazing experience unlike any other, and we made it to the quarter finals. I know I would've been really upset if our team didn't go. But still, in the end, Championships are Championships.
I still want there to be a way for teams that maybe don't quite make it all the way to get to experience the thrill, however. After all, it was only after going to Atlanta the first time that I really fell in love with FIRST. To deprive that from students just because their team may not be the best of the best would be detrimental to the program. Maybe have two divisions? Like, a field or set of fields for regional winners only (Chairman's winners can come play too ), and another for the other people? There is a downside in that the "others" wouldn't get to really experience the thrill of playing with some of the top teams. But it would allow them to go to Atlanta and give the top teams the matches they more deserve.
I don't know, like Justin I'm also just thinking out loud and my thoughts aren't 100% organized at all times.
Woodie Flowers asked for Super Nerds
We're giving him ÜberNerds
~Tweeeeter~
2010 Northeast Utilities Hartford Regional Champions
2010 WPI Regional Chairman's Award Winners
2008 Archimedes Division Champions
2008 Hartford Regional Champions
Unread 12-05-2010, 19:04
NickE's Avatar
NickE NickE is offline
_
7*Regionals + 15 Hall of Fame Teams + 7 Sustaining Teams from 1992 + 3 Last Year's Champions + 1 Last Year's EI Award Winner
There's some overlap between the pre-qualified teams, but its a few more than 7*regionals.
Unread 12-05-2010, 19:31
Andrew, it's 6* Regionals. The only case where there would be a 4th Champion would be the rare case where the Champion pulls in a backup team. That happens maybe once or twice per year, and can easily be covered by duplication elsewhere, or a Champion not being able to go (which happens more than you might think).
6* Regionals + 15 + 7 + 3 +1 - overlap +18 (the MI contingent)
For overlap, we'll assume none, other than 2 Legacy teams also being HOF. (I think that's the right number...)
Assuming that the number of regionals (not counting districts and not counting MSC as a regional) remains the same for next year, that's 42 pre-qualifiers/MI teams + 6*43 regionals = 300 slots, minimum, with only previously known overlap. Currently, the Championship is running about 340 teams.
Given that 1-2 new regionals are typically added per year, and the number of HOF teams goes up by one per year, (so the team count goes up by 13 per year), I give it 4 years before the minimum has to be the current size, or the qualification system gets tweaked again.
Second assumption: about 30-40 teams manage to get doubly qualified every year, either through multiple event wins or through EI/RAS/RCA combined with an event win. (Or through special circumstances.) That's another 30-40 slots available. 8 years before there's a tweak, maximum, assuming constant growth rate.
More small regionals means either bigger championship, or more districting systems popping up sending X teams apiece.
Fewer big regionals means smaller championship, or more open registration slots. However, a number of regionals are already crowded. So you almost have to add more... which adds to the more regional question.
Either way, I predict that inside of a decade, open registration for the Championship will be extremely limited unless there is some major change to the qualification system. I suspect that that change will be similar to MI's district system, when it comes.
Unread 12-05-2010, 12:15
yodameister yodameister is offline
The Mad Chemist
FRC #2791
yodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant future
Holy thread resurrection Batman!
Hey FIRST - We're going to need a lot more regionals! Raul Regional Competitions 41 08-11-2003 18:10
Chamionship Qualification - feedback needed ASAP! dlavery General Forum 97 11-10-2003 07:17
Making heads or tails of the new announcement... Jessica Boucher General Forum 66 26-09-2001 11:13
VCU and KSC regionals Manoel Regional Competitions 0 25-09-2001 13:44
The Future of Nationals Scott Wolfe General Forum 55 21-08-2001 00:48
