Auto and Teleop Modes Hate Eachother!!! HELP!!!
i can get my teleop to run fine, and then deploy my auto as a start up just like my telop, and it runs fine, but i can't have both at the same time. when i try to switch from teleop to auto on the driver's station it stays the same, i can have one but not the other, i don't know what to do will someone please help me!
Re: Auto and Teleop Modes Hate Eachother!!! HELP!!!
we are having the same problem so any help would be helpful
no, i think you misunderstand me, i should be able to have teleop running, and when i hit the switch to auto, the auto program should begin running (correct me if i'm wrong) but instead of this happening i only get either telop mode or auto mode, even when i switch the button on the driver's station only one program works
One thing we tried was taking out the "start com" that we copied into our autonomous code. That allowed both the autonomous and the teleoperated to work independently, but then we had issues with the motors not working in autonomous but (yes) working in teleoperated. We can't seem to get both pieces working. We should probably continue communicating and perhaps we can come to a conclusion that works for both of us.
The initial project code is all in one project and has one build spec for deploying to the robot. You don't want to create a new project for your autonomous. You want to edit the one in your project. And you do not want to drop any more of the start communications anywhere else in your program. One of those is the right number, and the template had it in the right location.
So that we can help better, which template are you using Basic or Advanced? Do you really have two projects, or did I misunderstand? Greg McKaskle |
#7
i'm using basic, and it's all under one project but seperate VI's
#8
Are you clicking the run button on your autonomous? To start it up, you should set the DS to disable, run the robot main, then you can enable either the tele or the auto. You should be able to switch back and forth as many times as you like.
Do the procedure above with auto first, then tele and report the results. Greg McKaskle |
#9
We were having problems until we realized that you must deploy from the Main project. There is a deploy button on the autonomous but if you load from here apparently only that vi gets loaded and Globals or something gets broken.
#10
(Put robot in teleop)Try running your main robot code vi, and then, while that is still running, open up your autonomous independent vi, and it should not be running. Keep your main code still running, and switch to autonomous on your DS. You should see the autonomous program run.
#11
we finally got our code to work thanks to a little luck
the problem we had was that our varibles were not inside of the while loop (or for loop if that is what you used) After we did that, though the code ran perfectly |
#12
We are having a similar problem but I don't understand how you fixed this. Are you using Labview or WindRiver?
| [FTC]: Multiple Programs or One Program with Multiple Auto Modes | kevin51292 | FIRST Tech Challenge | 4 | 02-01-2009 20:37 |
| Detecting Start of TeleOp Mode | Danny Diaz | Programming | 4 | 26-02-2008 01:37 |
| Autonomous and Operator Control modes | mjbshaw | Programming | 4 | 14-02-2008 18:13 |
| White Paper Discuss: C Programming and Autonomous Modes for Newbies | cbolin | Extra Discussion | 3 | 09-01-2008 19:32 |
| I hate the BCS and i really ha te KANSAS ST. | Jon Reese | Chit-Chat | 10 | 11-12-2003 12:09 |
