Go to Post Ooohh!! Fire!! - dlavery [more]
Unread 07-02-2009, 13:35
duffsta's Avatar
duffsta duffsta is offline
AKA: Matthew Duff
FRC #1386 (Trobots)
duffsta is an unknown quantity at this point
victor changes?
we have had some things not working out with speed controllers and was wondering if there was any difference from this year's victor controllers and victor controllers from previous years?
thanks much
Unread 07-02-2009, 13:42
Urban Hawk Urban Hawk is offline
Head of R&D and Head of Scouting
FRC #1886
Team Role: Scout
Urban Hawk is infamous around these partsUrban Hawk is infamous around these partsUrban Hawk is infamous around these parts
Re: victor changes?
yes there is... they are different models... this year is a victor 884 however in previous years we've used victor 883.
so... what are your problems...
FEAR THE HAWK!!!
Unread 07-02-2009, 13:46
duffsta's Avatar
AKA: Matthew Duff
FRC #1386 (Trobots)
Re: victor changes?
well, we had a jag blow on us and we are having a hard time getting everything to work properly.
trobots to nationals 2009!!!
Unread 07-02-2009, 13:54
writchie writchie is offline
Engineering Mentor
AKA: Wally Ritchie
FRC #2152 (Team Daytona)
writchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond repute
Re: victor changes?
2007 and 2008 were also Victor 884's. Can't say about years before that.
Unread 07-02-2009, 14:14
FRC #1886
Team Role: Scout
Re: victor changes?
well we have always used 883
these might help you...
for jaguar:http://tom-tech.com/first/wiki/image...ingStarted.pdf
for victor 884:http://www.ifirobotics.com/docs/ifi-...nual-dec04.pdf
looking at them the most likely problem may have been wiring since that seems to be one of the best ways when it comes to wrecking a victor so id suggest looking at the wiring guidelines section for the victors since it does list at the end several things you shouldn't do. For jaguar there isn't much on the manual about faults however on the first page there are 3 warnings of things you shouldn't do.
FEAR THE HAWK!!!
Unread 07-02-2009, 15:36
Re: victor changes?
In which case, you've been illegal for some years, unless you're mistaken about which number was on the Victors. I'm guessing the latter, or else the inspectors didn't know the rules.
884s have been the only legal Victors since at least 2006 (the last year for which a full manual is available--see http://www2.usfirst.org/2006comp/Man...obot_Rev_F.pdf, <R27>).
I personally remember the 883s being illegal since 2004 at least.
Unread 07-02-2009, 16:14
FRC #1886
Team Role: Scout
Re: victor changes?
well normally i don't work with the robot build much so i could easily be mistaken which we are using. ill have to go check with them.
FEAR THE HAWK!!!
Unread 07-02-2009, 20:01
Racer26 Racer26 is offline
Re: victor changes?
EricH is correct. 2003 was the transition year from Vic883s to Vic884s. 884s came in the kit, but you were allowed to use 883s if you had them, much like this year where you're allowed to use Jags and 884s.
However, there are quite a few differences between Jags and 884s. 884s have an update frequency of about 100Hz, while Jags have an update frequency of about 200Hz. Jags are also quite a bit more linear than 884s.
The code differences should be as easy as changing:
Jaguar *motor;
motor = new Jaguar(1);
to:
Victor *motor;
motor = new Victor(1);
in C++, or in LabVIEW, just replacing the Open Jaguar vi, with an Open Victor vi.
Chassis Changes Max Brin Technical Discussion 5 16-01-2006 17:53
Style Changes Brandon Martus CD Forum Support 33 20-06-2005 11:17
Victor 884's not behaving the same as Victor 883's programmer1 Programming 13 10-03-2004 21:51
Team 66 Changes David66 Western Region Robotics Forum 1 30-01-2003 14:51
Rule Changes? archiver 1999 6 23-06-2002 22:15
