jaguars suddenly not working
We were trying to program a bunch of separate buttons, and the programing part was going okay. We were troubleshooting and stuff, but then a problem occurred. The buttons were showing up, (the spikes were changing color,) but they were looping or something. Whenever a button was pushed, the spike light flashed like crazy. So, I altered the program to try to get it so that when a button was pushed, the spike light was continuously on, and now the I have blinking, disabled jaguars and nothing is working. I put the program back to the "semi-working" state and tried restarting everything, but it still doesn't work. Does anyone have an idea as to what the problem could be? The RSL light is solid.
Re: jaguars suddenly not working
The problem could be one of a hundred or more things. Without knowing more about your code, or at least what you want your code to do, anything I could suggest would just be a guess.
My first guess: you want your button to turn on the relay on the first press, and turn it off again on the next press. Is that correct? |
| Jaguars working with 2.4 Ghz R/C | NOV8R | Technical Discussion | 0 | 09-01-2009 16:15 |
| p2 not working? | Lone_Wolf92c | Programming | 5 | 22-02-2008 08:49 |
| IR Board Not Working (But NOT Fried) | itsme | Electrical | 2 | 18-02-2008 06:11 |
| gyro not working | johnsmith11111 | Programming | 4 | 14-02-2008 17:13 |
| Gyro not working | 1594code | Programming | 2 | 12-02-2008 18:16 |
