Go to Post the everyone is a winner philosophy cheapens winning. - Andrew Schreiber [more]
Unread 08-02-2009, 12:08
tbd tbd is offline
FRC #1577
tbd is on a distinguished road
Question about Rules regarding the cRIO
I was wondering wether its possible to disconnect modules from say slot 2, slot 6 and slot 8 (1 for analog, 1 for DS, 1 for Pneumatics), seal thier connection useing the KOP supplied rubber plugs. Is it possible to pass inspection? assuming i have slot 1 plugged in, and the jumpers on for battery monitoring, and assuming i dont use any other slot than slot 4 so i keep the other modules out of the cRIO... obivously for less weight.
couldnt find any rule aginst it on "The Robot" PDF, so if anyone can point me to a rule that says otherwise, it would be great.
Thanks in advance,
Steampunk 1577 Electronics Crew
Unread 08-02-2009, 12:52
Re: Question about Rules regarding the cRIO
You might take a look at Update #8. It doesn't say this directly, but it sure implies that you are correct.
Hole in the rules regarding causing penalties? BethMo Rules/Strategy 5 06-01-2009 11:20
Question about the pneumatics rules Astarties Rules/Strategy 1 31-01-2008 22:27
question about rules (size/orientation) Bochek Rules/Strategy 15 19-01-2007 18:23
What are the rules regarding joysticks, etc. for the Operator Interface? itay_ms Rules/Strategy 1 17-01-2007 12:16
