Go to Post "You fogot the gears!!!!" - The_Gman [more]
Unread 10-02-2009, 13:51
Rick's Avatar
Rick Rick is offline
Ready to STRIKE!
AKA: Rick Blight
FRC #0078 (AIR STRIKE)
Rick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond repute
[FTC]: Any teams using dead axles for arms?
Have any teams used a dead axle setup for an arm/manipulator? We are having some issues with the split clamps and our live axle setup, and I was wondering if anyone has any details or pictures about such a setup?
Like Aquidneck Island Robotics on Facebook!
Unread 10-02-2009, 18:26
ttldomination's Avatar
Sunny
Re: [FTC]: Any teams using dead axles for arms?
What do you mean dead axle?
1648: 2013-2014
5283: 2015
Unread 10-02-2009, 19:29
The axle is stationary and the wheel spins on it.
Unread 10-02-2009, 23:56
jgraber jgraber is offline
jgraber is just really nicejgraber is just really nicejgraber is just really nicejgraber is just really nice
FTC136 has a parallogram arm using the bronze bushings as pivots. Lets try a word picture:
Have two C channel uprights, with the arm pivoting between them. Stick a bronze bushing from inside the arm into the upright on both sides. Stick an axle through the whole thing, while threading spacers between the bushings to keep them from sliding to the inside. Screw a split clamp to the upright and clamp the axle to keep it from sliding. Alternately, use locking collars on each side to keep the axle in place.
So the axle merely holds things in place, and the sliding joint is between the large holes in the C channel, and the bronze bushing.
It seems like a 40 and 120 tooth gear bolted together could rotate on a bronze bushing in the same way. Hope this helps.
Unread 11-02-2009, 07:33
jbbjjbt jbbjjbt is offline
VRC Coach
AKA: Jon T
VRC #0177 (Twisted Botz)
jbbjjbt is an unknown quantity at this point
I don't have a solution, but we share the problem. It irritates me that we have these very powerful motors but only clamps to transmit the power. We have tried lots of ideas out to overcome this issue , but none have worked successfully very long.
Jon Thompson
Coach
VRC 177 Twisted Botz
Sponsored by FRC 122
NASA Knights
Unread 11-02-2009, 08:09
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
We had the same problem when we were brain storming arm ideas. Because of the weak clamps we opted for live axles. I hope FIRST is reviewing these posts and will be making improvements for next year's season.
Unread 11-02-2009, 15:53
dooey100 dooey100 is offline
FTC #3037
dooey100 is on a distinguished road
We have a setup a lot like this and it works great.
Unread 11-02-2009, 16:35
gregsanCHEVY121's Avatar
gregsanCHEVY121 gregsanCHEVY121 is offline
FTC #0121 (Rhode Rage and Air Strike)
Team Role: Operator
gregsanCHEVY121 is a jewel in the roughgregsanCHEVY121 is a jewel in the roughgregsanCHEVY121 is a jewel in the roughgregsanCHEVY121 is a jewel in the rough
Send a message via AIM to gregsanCHEVY121
Could any of the teams that do use dead axles post pictures of their steup? thanks
Unread 11-02-2009, 19:40
gdo's Avatar
gdo gdo is offline
Never too much duct-tape ;)
AKA: Patrick
FTC #0001 (Team Unlimited)
gdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to beholdgdo is a splendid one to behold
Send a message via AIM to gdo Send a message via MSN to gdo
are you guys using these deadaxle on the intermediates in your Arm's gear train. If so, try to bolt the two gears together with a long screw. Because I remember you guys saying they kept failing at the competition, meaning that one would no longer turn the other, if they were physically bolted together and the clamps "failed", but still remained physically attached, as long as they kept in the proper place in allignment, then you wouldn't have to worry about them fail. You could juts put a shaft collar at each end of the axel to hold the gears on the axel.
FTC #1: http://unlimited.syraweb.org
Got any question for me; AIM, MSN or PM me
Unread 11-02-2009, 21:11
Team Role: Operator
the problem we were having was that the clamps at the top gear of our arm were failing. we have a medium and small gear(i dont know the teeth number) on one axle, that sits between the big gear that is attached to the axle on the arm and a small gear that is on the motor. The center axle and gear setup does not slip or anything, it is always just the clamps that attach the big gear to the axle. We ended up figuring a way to get a clamp on each side of the big gear and putting a screw through the gear and two clamps. That seemed to fix our problem but it was an "on the spot" thing and we need to make it final or use something different such as the dead axle idea.
Unread 11-02-2009, 22:15
FTC #3037
Would it be possible for you to attach the gear directly to the arm? Mabey using a clamp as spacing?
Unread 12-02-2009, 14:31
Team Role: Operator
yes, that is one idea of ours. We might add another big gear to the arm that would attach directly to the arm so the clamp is not needed. We would then have a total of four big gears at the top of our arm, but if thats what it would take then it would be worth it. We may be able to get away with only using one big gear on each side that is attached directly to the arm.
Unread 12-02-2009, 23:01
BradMello's Avatar
BradMello BradMello is offline
Broken Arrow
FRC #0078 (Rhode Rage & AIR Strike)
Team Role: Driver
BradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant future
Send a message via AIM to BradMello
We could do this greg, Mt. Hope showed me how they did it
[FTC]: Tips page on using FTC Encoders with LabVIEW PhilBot FIRST Tech Challenge 7 27-01-2009 14:00
Voltage-to-resistance converter for using any joysticks ConKbot of Doom Control System 14 15-07-2006 12:13
Live vs. Dead axles sanddrag Technical Discussion 28 03-05-2006 20:49
have any teams had any luck approaching local malls for spaces to practice? amos229 General Forum 28 07-01-2006 10:30
for teams with arms sburro General Forum 14 18-05-2005 22:09
