problem while programming 2 bottuns in windriver
hey
we are trying to do 2 buttons for the same motor if button 1 pressed move forward .. else stop ... and then if button 2 pressed move backward else stop here is the code we are using but it doesn't work well : in the operatorcontrol we put this: Code:
if(leftjoystick->GetRawButton(1));
jaguar->Set(1.0);
else{
jaguar->Set(0.0);
if(leftjoystick->GetRawButton(2));
jaguar->Set(-1.0);
else{
jaguar->Set(0.0);
jaguar->Set(-1.0);
else{
jaguar->Set(0.0);
please need answer Last edited by mahmosh : 12-02-2009 at 09:14. |
Re: problem while programming 2 bottuns in windriver
Its a logic error, if you hold down button 1, then that will set the motor to 1, then since button 2 is not held down it will go to that else which will set it back to 0.
Because you have two separate if...else statements, if the reverse button isn't held down, the output will be zero regardless of the forward button's state.
Also, this: Code:
if (condition); A quick rewrite yields this: Code:
jaguar->Set(1.0);
else if (leftjoystick->GetRawButton(2)) {
jaguar->Set(-1.0);
} else {
jaguar->Set(0.0);
Alan Anderson let me know that I messed up. I misread your code snippet: I didn't realize that the reverse button would drive the motor in reverse... (crosses eyes) I really need some more sleep. Let me know if you have any more questions or problems. Jacob Last edited by JBotAlan : 12-02-2009 at 17:21. Reason: Oops. |
thank you
it works well .... if i have any questions i will ask here |
| WindRiver Programming Template | kyungjin | C/C++ | 0 | 24-01-2009 16:42 |
| Potentiometer on cRIO, Programming in Windriver | sircedric4 | C/C++ | 3 | 20-01-2009 06:42 |
| WindRiver Programming | dnrobotics11 | C/C++ | 1 | 19-01-2009 20:13 |
| WindRiver Programming | dnrobotics11 | C/C++ | 4 | 19-01-2009 19:43 |
| Problem debugging code with WindRiver | LinuxMercedes | Programming | 3 | 07-01-2009 11:10 |
