Go to Post I would rather KEEP the structural integrity of my skull, thank you. - carpedav000 [more]
Unread 12-02-2009, 15:08
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
pic: 1388: Gyration
Unread 12-02-2009, 17:13
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
seanl will become famous soon enoughseanl will become famous soon enough
Re: pic: 1388: Gyration
nice job guys, we were going to attempt to put a gyro on ours as well but we scrapped the device because it was out of our weight constraints. good luck in your season and we'll see you guys at Long Beach.
, Sean
TEAM 867
-electrical
-pneumatics
-programming
2008 Autodesk Visualization Grand Prize Winner
Unread 12-02-2009, 17:25
Zyik Zyik is offline
Observer
Zyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond repute
Is the mechanism for picking the balls up off the floor only one ball wide? That seems like it could be a serious disadvantage.
Team 973 : 06-09
Unread 12-02-2009, 17:27
AdamHeard's Avatar
Lead Mentor
Do you have an electronic gyro measuring your turning as well? It would seem to be extremely difficult to accurately turn via a spinning gyro without some closed-loop control software.
Unread 12-02-2009, 17:56
Doug Leppard's Avatar
Doug Leppard Doug Leppard is offline
FRC #1902 (Exploding Bacon)
Doug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond repute
Send a message via AIM to Doug Leppard
Wow you guys pulled it off. We looked at this method and built a proto-type but didn't think it would help as much and didn't have the room and weight, but you guys did it, congratulations.
Doug Leppard
Unread 12-02-2009, 18:14
run the trap!!!
Team Role: Human Player
erm... I hope our 7lb. shooter drum doesn't affect our driving
-Philip J. Fry
Unread 12-02-2009, 19:24
Eric Bareiss's Avatar
Eric Bareiss Eric Bareiss is offline
It's a Bird
AKA: BoogyShoes
FRC #1492 (Team Caution)
Eric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of light
Send a message via AIM to Eric Bareiss
I'm assuming you have the gyro spinning the same direction the whole time. Correct me if I'm wrong, but shouldn't the gyro tip side to side instead of front to back? The physics of this gyro looks sideways. If the gyro is spinning to the right and you tip it forward, the force would be forward, which doesn't help with turning.
I Hate Signatures!
Unread 12-02-2009, 21:39
Ozeaden Ozeaden is offline
FRC #1388 (Eagle Robotics)
Ozeaden is an unknown quantity at this point
The physics do not change and as the default position of the gyro is vertical the tourque does not affect driving unless tilted...which is the point...obviously...
http://www.eaglerobotics.com/
Unread 12-02-2009, 21:59
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Ok, I got to know. What did you do to your bumpers? Did you wrap them to your frame?
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 12-02-2009, 22:06
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Looks like they wrapped them in tape to keep the numbers on...
I really like the gyro idea though. It's very different and should land you an award... if not a win
-Dustin Benedict
Unread 12-02-2009, 22:33
grantman54's Avatar
grantman54 grantman54 is offline
None #1388
grantman54 is an unknown quantity at this point
WOW im impressed with the outcome. seriously good work guys
Unread 13-02-2009, 00:00
Very cool. I think you're well on your way to a 3rd straight creativity award.
See you in LA.
pic: 1388 Hammertime grantman54 Extra Discussion 5 16-04-2008 12:09
pic: 1388 Presents: Lucky! BQuennell Robot Showcase 5 26-02-2007 02:12
pic: Team 1388: Finished Mike Hendricks Robot Showcase 10 22-02-2006 22:52
pic: Team 1388 Gearbox Mike Hendricks Robot Showcase 5 07-02-2005 17:26
pic: Team 1388 Teaser Mike Hendricks Extra Discussion 10 27-01-2005 10:28
