Okay, so for some reason, on certain computers, the IE version of our home page is cluttered/messy and simply is not fitting properly. However, on other computers, the IE version of the site works perfectly.
Firefox however, works perfectly, regardless. Is it the IE updated version, or is something with the coding? Please help! Sincerely, Maria Deslis http://www.shazbots.org |
Re: IE is confusing me :(((
It looks the same for me in IE, Firefox and Chrome.
I believe what you are seeing is certain browser configurations rendering the markup differently. I ran the code through a validator and found that there are many elements out of place. http://validator.w3.org/check?uri=ht...Inline&group=0 This will cause IE to display differently. Try and clean up the code and see how it renders. HTH |
Try and fix all of the errors that show up on the validation page. That can fix some problems like this. If you need any help, or don't know what these errors are for. You can PM me and I can help ya.
Thank you so much you guys! It really did help when I used it! I finally figured things out thanks to that validation code! I really appreciate you guys taking the time to help.
![]() Things are now running smoothly in all browsers. Do you guys know what browser the web judges check the site in? |
No idea personally. I would say that you might want to check older versions of IE for sure. It's notorious for not being standards compliant, and I had similar issues a couple months ago. Also, I noticed you're using XHTML. I talked to someone a few weeks ago who does web design professionally, and it turns out that a lot of errors W3 spits out are bogus in XHTML. Here's what I've got from him in an email:
Also, use conditional statements if you're still having trouble. Unfortunately, I'm not very good at explaining them, so perhaps someone else could do the honors, or maybe a little research is all you need. |
I'm judging for the Chesapeake regional, and I'm mostly using Firefox on my Vista laptop. If something appears strange I'll take a look in Safari 3, IE 7, Chrome and Opera 9.5 though. I did run into one site while grading that worked perfectly on Safari 3 only, and did not work correctly on any other browser. (So 95% of Windows users could not use the site properly) |
| Confusing Video | Bochek | Technical Discussion | 13 | 14-02-2007 13:36 |
| Confusing Shipping date, NYC regional | Denman | Rules/Strategy | 1 | 02-02-2005 11:14 |
| Confusing Compiler Error | UrsaMNet | Programming | 2 | 28-10-2004 14:32 |
| One Confusing Math Problem | Bharat Nain | Math and Science | 4 | 01-02-2004 17:21 |
| Ahh! Program trick confusing! | archiver | 2001 | 9 | 24-06-2002 02:26 |
