Go to Post I dont think it matters too much what you do, as long as you do something that lets you apply what you're learning in class. - MrForbes [more]
Unread 12-02-2009, 22:28
xtreampb's Avatar
xtreampb xtreampb is offline
Lead Programmer 2642
FRC #2642 (Pitt Pirates)
xtreampb is an unknown quantity at this point
Send a message via AIM to xtreampb Send a message via Yahoo to xtreampb
Modifying .CPP files
Hey guys. I want to modify the RobotDrive.CPP file but i can't find it in the wind river directory. I found the .h File but I need to add a member function to the .CPP file. Can anyone give me the directory path please thanks
~Xtreampb~
Pitt Pirates 2642
Unread 12-02-2009, 22:30
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: Modifying .CPP files
You have to download the library from wpi site, the source that comes with windriver is all pre compiled
http://first.wpi.edu/FRC/frcupdates.html
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 12-02-2009, 22:36
xtreampb's Avatar
I have the updates and have downloaded the source code. Are you saying that i have to go to where i downloaded the source code, codify the .CPP and the .H files then re-install them?
Thanks
~Xtreampb~
Unread 12-02-2009, 23:52
TimCraig TimCraig is offline
AKA: Tim Craig
TimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to behold
~Xtreampb~
Pitt Pirates 2642
Depending on "how" you want to change it, a good way would be to derive your own new class from RobotDrive and either override the methods you want to behave differently and/or add new methods and data to it. This is the beauty of object oriented programming.
Unread 12-02-2009, 23:56
xtreampb's Avatar
I just want to add a single function to the already used RobotDrive class. I am using one of the previous functions in it, arcade drive, but i want to use a single drive function that uses a single PWM channel (we have more than we need ,24, so i was told i can use as many as i wanted) Even if i wanted to override the current one, i dont know how to do this in wind river. I can do it using Visual C++ (another question i have was could i export these libararys to VC++ libary colection but that is another topic for later)
~Xtreampb~
Pitt Pirates 2642
Lead Programmer
Unread 13-02-2009, 00:34
That is a perfect situation for creating a new class that inherits from RobotDrive.
Unread 13-02-2009, 15:23
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
I would create a class like such:
class OurRobotDrive:private RobotDrive
public:
void ourFunction(int speed)
and you can still have the other functions!
Watchdog.Kill();
Unread 15-02-2009, 00:40
AKA: Tim Craig
public:
Generally, if you want all the public members in the base class visible for the "is-a" relationship, you would use public inheritance. You don't see private inheritance used much.
Unread 24-02-2009, 22:24
xtreampb's Avatar
ok thanks for all of yall's help. I built my class and have implemented it into the code, unfortuanatly i wasn't able to test the code before we had to ship it off but i have ran into an error with my deconstructor
error: declaration of 'Our_Drive::~Our_Drive()' outside of class is not definition
i dont have an error about the deconstructor in my header file, just in the CPP file. how do i fix this?
~Xtreampb~
Pitt Pirates 2642
Lead Programmer
Unread 26-02-2009, 22:30
xtreampb's Avatar
i fixed it, i had placed a simi colon after my function declaration, a rookie mistake
~Xtreampb~
Pitt Pirates 2642
Lead Programmer
Location of WPI Library cpp files attached to Windriver marccenter C/C++ 5 11-02-2009 12:47
Bug (?) in Target.cpp in TwoColorTrackingDemo Mike Mahar C/C++ 0 02-02-2009 09:48
Need Help Locating .h and .cpp files jkjohnson Programming 0 30-01-2009 09:00
NiVision.cpp nickmagus Programming 4 26-01-2009 08:55
CAD Help needed. Mech Desktop 6 files backwards to AutoCAD 14? (2d files) Elgin Clock Inventor 0 30-08-2004 23:06
