Go to Post I think that this clearly indicates that 2017 will be the year we finally see 3.63 robots per alliance. - Caleb Sykes [more]
Unread 13-02-2009, 17:56
hullingerbr hullingerbr is offline
FRC #1724 (Weber Fever)
hullingerbr is an unknown quantity at this point
Question Centering turning
Hello. I was wondering if it was possible to make it so that when you let go of the joystick, the motor returns to a pre-set position. Any help?
Unread 13-02-2009, 18:37
Someone told me there was food here
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Re: Centering turning
Joystick: Get axis then if whatever axis=0 set motor to your speed. If you can't get it from that I could make an example.
EDIT: I don't have a robot or a cRIO in front of me so this would be pretty vauge but this is the idea:
Unread 14-02-2009, 08:53
That's too large a topic to answer quickly in a forum like this. Do a web search (or even just a Chief Delphi search) for "position PID". You'll need an absolute position sensor on whatever your motor is controlling; quadrature encoders alone won't be enough.
Unread 14-02-2009, 09:45
airnate airnate is offline
FRC #0236 (Techno Ticks)
airnate is a jewel in the roughairnate is a jewel in the roughairnate is a jewel in the rough
We use potentiometers attached to the steering axis to give us feedback on the current steering angle. From this we can actuate the motors to steer to a specific angle.
turning a turntable caffino54 Technical Discussion 2 07-02-2009 01:45
Optical Encoder Centering Tool Gary Bonner Kit & Additional Hardware 1 05-01-2009 18:19
Need Help Centering Page TeAm270RoCkS Website Design/Showcase 6 10-02-2008 18:10
Turning 18... Astronouth7303 Chit-Chat 16 22-05-2006 09:29
Centering, and other tools, in Inventor? LBK Rules Inventor 6 15-01-2004 00:31
