Go to Post I wouldn't want to replay Lunacy -- the Moon is a harsh mistress! - Richard Wallace [more]
Unread 14-02-2009, 01:23
bio hazard bio hazard is offline
FRC #2375
bio hazard is an unknown quantity at this point
Arrow cRio keeps on staying red on the lab view conection test all other 4 lights are green
cRio keeps on staying red on the lab view connection test all other 4 lights are green please help.
Unread 11-03-2010, 13:51
randalcr's Avatar
randalcr randalcr is offline
Programming Mentor
AKA: Chance Randall
FRC #0476 (Wildcats)
randalcr is an unknown quantity at this point
Re: cRio keeps on staying red on the lab view conection test all other 4 lights are g
What do you mean?
-Time is the best teacher...unfortunately it kills all of its students. --Robin Williams
Unread 11-03-2010, 16:48
If you're talking about the communication status indicators on the Driver Station display, red means the cRIO is not responding to a network ping. That could be due to power (the cRIO might not be on), wiring (the network cable from the WGA to cRIO's ethernet port #1 might not be making a good connection), or software (the cRIO might not be formatted with the proper team number selected).
Verify that you have 24 volts on the cRIO's power connector.
Check the ethernet status LEDs on the cRIO. The green one should be on solid if you have a good connection to the WGA. The yellow one should flash with network activity.
Try reimaging the cRIO, following the instructions in the control system manual exactly.
cRio keeps on staying red on the lab view connection test bio hazard Programming 1 14-02-2009 19:45
Encoder support in NI Lab View Lafleur Programming 1 31-01-2009 12:09
Lab View Schotty57 Programming 5 02-04-2008 20:24
pic: Bottom view of The Red Dragon redbarron Extra Discussion 27 02-02-2007 10:20
Lights (not the green target light) FourPenguins Electrical 10 23-01-2007 13:23
