Go to Post You know FIRST is on the level of sports when you can give predictions like sports casters do. :) - RoboMaster [more]
Unread 14-02-2009, 11:28
Booksy Booksy is offline
FRC #1244 (Viking Robotics)
Booksy will become famous soon enoughBooksy will become famous soon enough
Digital Sidecar problem
Our digital sidecar doesn't always work. I'll download code, and it may or may not work. I then have to restart the system and try again. When it doesn't work, it gets power and appears to be functioning, but the jaguars flash and spikes and DIO's don't work. The analog sensor in the analog breakout still works, however. The DSC has all lights lit up. RSL is solid.
Any ideas greatly appreciated.
My favorite CD quote ever(taken out of context of course):
Originally Posted by ttldomination
water would be hard to build
Unread 14-02-2009, 19:47
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
Re: Digital Sidecar problem
Sounds like your 37 pin cable to the digital sidecar might be loose or faulty.
Have you tried securing the cable or swapping the cable ?
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 15-02-2009, 21:41
p00rleno p00rleno is offline
Team Advisor & Former Team Leader
AKA: Andy
FRC #2590 (Nemesis)
p00rleno is on a distinguished road
Sounds like a software issue we had. If you're in LabVIEW anyway. Something, somewhere got messed up and we couldn't get a signal out, even though it was wired properly and all. Ended up just migrating the code to a new project, where it worked fine. Took all of 5 minutes. Might work.
Unread 28-02-2009, 00:06
morganh2550's Avatar
morganh2550 morganh2550 is offline
Actuationator
FRC #2087 (BFG)
Team Role: Electrical
morganh2550 is just really nicemorganh2550 is just really nicemorganh2550 is just really nicemorganh2550 is just really nicemorganh2550 is just really nice
Lightbulb Re: Digital Sidecar problem
This resembles a issue we had earlier in the year does the sidecar get hot? Do the lights turn on? If yes to the first question you have fried it, take it apart to confirm (the lights may still turn on). If the lights don't turn on then check the wires and the cable.
Before you do anything ask yourself, "Did I do this right?", "Will it blow up?"
Unread 01-03-2009, 18:15
I forgot about this, it fixed itself though... thanks anyway. I have no idea with the electronics this year sometimes. They just stop working for no apparent reason, and they fix themselves... It's weird.
Unread 01-03-2009, 18:26
There are a lot of protection methods in the electronics this year that have the "It doesn't work but at least it isn't broken" feature.
For example, all of the power supplies will shut down if they are shorted out, rather than roast themselves. I've heard of several "incidents" where a dynamic short on the DSC's 5V rail will sporadically kill the motors.
When a supply goes into this fail safe it doesn't push enough current to smoke things, so it looks perfectly fine - and also perfectly broken. Hopefully the LEDs help with this.
Worse, some are protected by thermal devices, so it will take 5-15 seconds to "heal".
Unread 14-06-2009, 05:31
Ranana_Prussy's Avatar
Ranana_Prussy Ranana_Prussy is offline
Ranana_Prussy is an unknown quantity at this point
Will you be investing in in an scx digital system bearing in mind you will probably have to buy new cars track and accesorys?
No RSL on Digital Sidecar shobuda999 FRC Control System 16 08-02-2009 14:28
Digital Sidecar Problems cabbagekid2 FRC Control System 13 31-01-2009 17:23
Digital Sidecar Not Working tseres Electrical 9 31-01-2009 17:22
Digital Sidecar Resistor NinJA999 Electrical 5 30-01-2009 19:53
Fusing for Digital Sidecar (was: HIZZELP) KilroyLaxer FRC Control System 4 15-12-2008 20:44
