Controlling 2 pneumatic valves w/ 1 spike
Is using two pneumatic valves on one spike legal? How should I connect them?
Re: Controlling 2 pneumatic valves w/ 1 spike
yes it is legal.
... actually, you'd need to put +12v and GND on the input side of the spike from your power distribution board, then, on the output side of the spike, you wire up the RED wire from the first solenoid to M+, the RED wire from the other solenoid to M-, and take both of the blacks from both solenoids back to ground.
Drive the spike "forward" and you get one solenoid active, drive it "backward" and you get the other solenoid active. |
Also, you don't technically need to use a spike to control a pneumatic valve. You could just rig up the relay bumper on the cRIO. I'm pretty sure its legal to hook up two solenoids to one connection on the relay bumper, but I'm not positive, so as our team says, RTFM. (Read the FIRST manual)
(And yes, the F in RTFM didn't always stand for FIRST) |
Xela,
What you are asking is legal but not always desirable. I would suggest you check out the Spike manual on the IFI website http://www.ifirobotics.com/spike.shtml. There is some application notes in the manual that you might find useful. |
| Needing pneumatic valves | Brown | General Forum | 3 | 20-02-2008 19:32 |
| 2 FESTO valves on 1 spike | bhsrobotics1671 | Electrical | 12 | 08-02-2008 13:37 |
| wiring pneumatic soleniod valves | GeorgeC | Pneumatics | 3 | 07-04-2007 08:02 |
| small pneumatic valves | technic master | Technical Discussion | 8 | 07-10-2004 19:18 |
| Pneumatic valves in 2004 Kit | gburlison | Pneumatics | 2 | 13-01-2004 12:49 |
