Go to Post I guess it all just goes back to the fact that you need to finish your robot before it goes in the crate. - sanddrag [more]
Unread 14-02-2009, 20:20
psychomonkey psychomonkey is offline
Mr. February
AKA: Seth Rhodes
FRC #1592 (Bionic Tigers)
psychomonkey is an unknown quantity at this point
Exclamation Upside-down Camera Gimbal Problems
My team and I have decided that it would be beneficial to hang our camera upside-down this year. The problem with that is that after I flipped the camera over on the mount, the x-axis has been inverted, so that whenever the colors appear on the side of the mask, the gimbal goes the opposite direction. We would like to negate the x axis search pattern, however, I do not know how to do this. I am using LabView. If anybody could give me some tips, that would be much appreciated, and I might even put a good word in for you to the man upstairs.
Unread 14-02-2009, 21:05
Re: Upside-down Camera Gimbal Problems
Open the VI that does the Servo Control State Machine. On its panel are Proportional(div) values. You will want to negate the X value. Try it out, and if works, make the current value default and save it.
Greg McKaskle
Unread 25-02-2009, 15:35
Mr. February
AKA: Seth Rhodes
Thank you for the comment and yes I tried that but it did not work very well.
I was wondering if anyone else had any other opinions?
I am currently a hoopy frood. So please post any decent suggestions.
Unread 25-02-2009, 15:58
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
I know our programmers did it, but we're using C++. I'll ask them if there's a specific variable, method, etc, when I get a chance. We'll be at the Florida regional to help out if you can't fix it by then.
GitHub
Unread 25-02-2009, 17:04
Luke Pike's Avatar
Luke Pike Luke Pike is offline
Programmer
FRC #1501 (THRUST)
Luke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to all
I think all you have to do is flip the image on the camera. Just plug the camera into your computer, visit it's IP address, and there should be a setting to rotate the image. Set the rotation to 180 degrees, and you should be good to go.
Twitter Profile
Unread 25-02-2009, 17:14
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Or, mount the camera right side up in an up side down gimbel.
Unread 01-03-2009, 19:08
Mr. February
AKA: Seth Rhodes
OK, so I have the camera right-side-up on an upside-down gimbal. The problem only starts here. This is what causes the x-axis to be backwards. I have made an attempt at inverting it. I put a case structure in the upper corner with an unbundle and a bundle in order to just invert the x axis. Is this right?
In a time... When the greatest comeback occured... There was... MR. FEBRUARY!!!
Unread 01-03-2009, 19:18
I don't think that will work. You are flipping the value every time it is called, so it will oscillate.
My post on flipping the proportion really is the thing you want to do. What I didn't tell you to do was to find the other places that are adjusting the position and negate their X value as well. A good example is in your Lost-Edge case. The 7,-5 also assumes a certain mounting. Constants like that also need to be negated.
Greg McKaskle
Unread 01-03-2009, 23:03
Mr. February
AKA: Seth Rhodes
Should that 320 and 240 be -320 and 240 as well?
Unread 02-03-2009, 08:40
Nope. Those are camera pixel offsets. Sorry there aren't better indications of units. That is where the math that was done for a specific camera resolution is being corrected to be in percent so that it is compatible with other camera resolutions.
Greg McKaskle
Unread 03-03-2009, 21:34
Mr. February
AKA: Seth Rhodes
Ok, thank you. I got it working. I had to redownload the two color servo example and put in all of the proper gains to get it to where I started from. Then I changed only what you told me to change. Gee I don't think that my foot could get any further into my mouth. Thank you for all of your help.
Mount Camera Upside Down LukeRu Programming 2 20-02-2006 20:15
Is CMUcam upside down?!? HELP! Calvin Programming 1 08-02-2006 18:44
pic: Genia upside down! Bridgette Extra Discussion 13 26-04-2005 09:21
CMUCam Upside-down? ahecht Programming 8 27-02-2005 10:25
pic: 322 upside down...and paul sees a ghost? CD47-Bot Extra Discussion 4 05-04-2004 00:13
