Go to Post Start simple and build up. - Mark McLeod [more]
Unread 19-02-2009, 14:02
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
2 sets of bumpers legal?
Our team colors have always been red and blue. This year we built 2 complete sets of bumpers for our robot. One red set and one blue set. We would like to be able to swap out the bumpers from match to match depending on if we are on the red alliance or blue alliance simply to match the alliance color (and the color of the trailer we are attached to). I am wondering if other teams have done this in the past and if it is legal. How would multiple sets of bumpers be viewed in the rules and during inspection? Would they be like batteries that you are allowed to swap in and out as desired or would they be considered alternate configurations of the robot? Is one set a spare or do both sets have to be weighed in at the same time and be less than 18lbs collectively? I have read the rules and can see it being called either way. Bumpers like batteries are not part of the robot weight and so I wouldn’t think they would be considered an alternate configuration, however, bumpers have their own weight restrictions and batteries do not. Our two sets of batteries will not make the 18lb limit collectively but each individual set do, of course. What rules would govern this situation?
Unread 19-02-2009, 14:04
A Bear's Avatar
A Bear A Bear is offline
FRC #2333 (Roboswitch Engage)
Team Role: Student
A Bear is an unknown quantity at this point
Re: 2 sets of bumpers legal?
I think so but im not sure...i want dual bumpers lol
Unread 19-02-2009, 14:06
Joe J.'s Avatar
Joe J. Joe J. is offline
My Gaming Is FIRST!
AKA: Joey
Joe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond reputeJoe J. has a reputation beyond repute
Send a message via AIM to Joe J.
Sounds like a Q&A question to me. Though I seem to remember hearing of teams doing this in the past.
Joe Jagadics
Lead Mentor / Coach
Lightning Robotics FRC Team 862
Unread 19-02-2009, 14:07
Answer #1: Go to Q&A.
Answer #2: It was fine last year (under last year's rules, which are not the same as this year's).
Answer #3: I would guess that they'd be illegal because they don't make weight together. Why do I say that? <R13> says that you have to weigh all possible configurations (of the robot) together.
Answer #4: Hi ho, hi ho, it's off to Q&A we go!
Unread 19-02-2009, 14:10
A Bear's Avatar
Team Role: Student
but i thought bumpers dont coult for the weight....
Unread 19-02-2009, 14:13
They don't. They have their own weight limit of 18 lbs. The question is whether <R13> applies only to the robot or applies to the robot and the bumpers independently.
Of course, then there was one team with two sets of bumpers who didn't pass inspection last year... but they had other issues with inspection.
Unread 19-02-2009, 14:15
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
If you're referencing 1519, that's a completely different issue. Let's try and keep that issue apart from this one to avoid confusion.
Unread 19-02-2009, 14:20
wo-bot 141's Avatar
wo-bot 141 wo-bot 141 is offline
AKA: cory walters
FRC #0141 (WO-BOT/COLD LOGIC)
wo-bot 141 is a splendid one to beholdwo-bot 141 is a splendid one to beholdwo-bot 141 is a splendid one to beholdwo-bot 141 is a splendid one to beholdwo-bot 141 is a splendid one to beholdwo-bot 141 is a splendid one to beholdwo-bot 141 is a splendid one to behold
I have seen teams in the past switch out bumpers. for example... wildstang switched bumpers in the elimination rounds in 2006 if I recall. all i think you would have to do is weigh them both so the are both legal. Still i would got to Q&A to be sure. but like i said you should be fine.
Unread 19-02-2009, 14:21
In 2006, bumpers weren't required. They could have run without them if they wanted. Still, Q&A.
Unread 19-02-2009, 14:31
wo-bot 141's Avatar
AKA: cory walters
Right they were not. we didn't like the idea of bumpers so our team decide not to put the on so we could have more kinetic energy with the robot.
Unread 19-02-2009, 15:15
Jared Russell's Avatar
Taking a year (mostly) off
Provided the other set of bumpers was functionally identical (and I would argue that color has nothing to do with function when it comes to bumpers), I believe that these would be spare parts and so unrestricted.
But what I say means nothing...ask the Q&A.
Unread 19-02-2009, 15:52
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
We were one of those teams over the last two compeition seasons (Rack-n-Roll and FIRST Overdrive) that had color changing bumpers. In both instances they were legal as long as each set was built to spec. But, with the all of the bumper issues this year, I would definantly check with Q&A.
We decided against this year because our graphics team wanted to make sure the bumpers fit into the color theme of the robot graphics, website, buttons, etc.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 19-02-2009, 16:51
As you are only using one set of bumpers at a time, there is no effect on overall robot weight during a match. I would expect the Q&A to agree that this is legal. However, each set of bumpers will still need to be inspected and weighed separately. Please check in with your lead inspector for the latest if the Q&A is not answered. If you showed me two different designs for the bumpers, i.e. they are not identical in form, function and weight, I would ask you to choose one.
Unread 23-02-2009, 22:34
suj's Avatar
suj suj is offline
Alumni/PartTime-Mentor on Team 1219
AKA: Sujeethan Vishnumoorthy
FRC #1219 (Iron Eagles)
suj is an unknown quantity at this point
Send a message via MSN to suj
well i doubt it there doesn't seem to be a reason for it to be illegal it's like making a quick change before competition what's wrong with before matches it's not like we're swapping parts up for something illegal and ridiculous like a handsaw or rockets
Programming Captain: 09/09 - 06/12
Drive Team: 2011-2012
Mentor: Sept 2012
Admin of the Team 1219 Facebook page: https://www.facebook.com/Team1219
http://i46.tinypic.com/i52els.jpg
Unread 22-02-2009, 20:23
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
Even though it's a completely different matter and unrelated to the original question in this discussion, 1519's bumpers last year between both robot configurations were within the 15-pound weight limit. We had a set of of six bumpers (some of which were quite short) which altogether weighed less than 15 pounds. Only four of the six bumpers would be on the robot for any given match.
If you can make your two complete sets of bumpers together satisfy the weight limit (as well as all the other bumper requirements) I would think you should be fine.
However, the GDC took the exact opposite perspective last year, ruling that all the bumpers needed to be on the robot at one time.
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
Segway sets course for stock market Melissa Nute Dean Kamen's Inventions 4 30-05-2006 10:30
How 1072 sets off fire alarms whakojacko Robot Showcase 3 23-02-2006 18:40
Vex and Erector Sets? jeffmorris FIRST Tech Challenge 1 03-10-2005 13:16
Rookie Allstars: what sets you apart? Greg Needel Championship Event 1 07-04-2005 16:48
Dean sets IT release date! archiver 2001 4 24-06-2002 01:43
