Wiring an Analog Sensor to Drivers Station
In order to wire an analog sensor to the drivers station, in this case a potentiometer, do I need any type of resister between the sensor and the drivers station.
Thank you for any help you can provide, DavidB |
Re: Wiring an Analog Sensor to Drivers Station
A pot is a variable resistor, so no you do not need another resistor as part of the wiring.
+5v to one end, ground to the other end, and signal to the wiper. |
Thank you for the help.
| Drivers station problems | Chris11246 | Programming | 7 | 16-02-2009 19:36 |
| drivers station digital input trouble | finman | Electrical | 9 | 16-02-2009 08:06 |
| Drivers Station Magical Current | 3DWolf | Electrical | 5 | 25-01-2009 21:52 |
| Drivers' Station Camera Feed | dhawk085 | Technical Discussion | 4 | 25-01-2009 19:12 |
| Telling drivers station your alliance | Mike Mahar | FRC Control System | 5 | 17-01-2009 08:43 |
